• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Active Member
    MATTR
    using apprentice to write iproperties interference from the Vault
    201 Views, 1 Replies
    09-22-2010 03:09 PM
    I am using an excel macro to open drawings for each part in an assembly and in the macro I am using apprentice to fill in custom iproperties in the drawing which fill out the release block that we use when we send a print to the floor.  This works great if the idw file is checked out from the vault.  however if it is not checked out apprentice cannont save the iproperties which means they aren't there when the drawing opens.  Is it possible to check out a part using apprentice?  Or maybe there is a better way to do this?  I would rethar not have to check out a drawing manualy and then fill in the i properties and then undo the check out after I print etc.
    Please use plain text.
    New Member
    banditos
    Re: using apprentice to write iproperties interference from the Vault
    04-15-2011 12:02 PM in reply to: MATTR
    Hello Mattr,
    I cant help you with Vault but I'm interested to learn how to access iProperties with an Excel macro. Can you send me an example code snippet that can manage this?
