Since you recently asked this question in another thread, I decided to respond to the orginal thread.
Concerning HDD interactions to place files:
This is based off the VBA example given in
Help section > Additional Help > Programming Help > Sample Code section
I have converted it to iLogic for you
' Set a reference to the assembly component definintion.
' This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Set a reference to the transient geometry object.
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
' Create a matrix. A new matrix is initialized with an identity matrix.
Dim oMatrix As Matrix
oMatrix = oTG.CreateMatrix
' Set the rotation of the matrix for a 45 degree rotation about the Z axis.
oMatrix.SetToRotation(3.14159265358979 / 4, oTG.CreateVector(0, 0, 1), oTG.CreatePoint(0, 0, 0))
' Set the translation portion of the matrix so the part will be positioned
' at (3,2,1).
oMatrix.SetTranslation(oTG.CreateVector(3, 2, 1))
' Add the occurrence.
Dim oOcc As ComponentOccurrence
oOcc = oAsmCompDef.Occurrences.Add("C:\Vault Local Files\test.ipt", oMatrix)
There is a lot more you can do with this obviously, but that's the basic idea.
Concerning Vault interactions to place files:
You'll have limited access inside of Inventor. The VaultAddin itself can be refrenced directly in VBA, BUT you will be blocked from using it by Autodesk. If this were possible, it would be simple. You would just Tools > Refrence > Browse inside of VBA and simply add C:\Program Files\Autodesk\Inventor 20XX\Bin\InventorVault.dll which would enable you to write custom scripts to do anything you wanted to do - like this:
Sub Blocked()
Dim oVault As New VaultAddInLib.FileUtility
Dim Result As FetchFileResult
oVault.CheckOutFile "C:\Vault Local Files\fubar.ipt", Result
If Result = kFetchFileSuccess Then
'do your thing
Else
'Report the error to the user
End If
End Sub
But like I said, you can't.
You can trigger the actual commands used by the VaultAddin from VBA or iLogic, but the moment it requires some sort of user interaction you will be out of luck, because Autodesk has chosen not to include the actual Vault Browser Pane in the API - you can play with the Inventor Browser Pane all day however. So you would still be forced to do some actions manually.
Example:
oCommandMgr.ControlDefinitions.Item("VaultGetLatest").Execute
oCommandMgr.ControlDefinitions.Item("VaultGetCheckoutTop").Execute2(True)
oCommandMgr.ControlDefinitions.Item("VaultCheckinTop").Execute2(True)
oCommandMgr.ControlDefinitions.Item("VaultChangeStateTop").Execute2(True)
Your best bet is to develop your own standalone application where apprentice will have access to everything or your own Add-In that would have access as well. Here's an example of what you are looking at:
http://forums.autodesk.com/t5/Autodesk-Vault/GetFiles-using-NET/td-p/3018348
Hope this helps.
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
