• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    j.vanderheijden
    place iLogic Component
    129 Views, 1 Replies
    12-28-2012 09:22 AM
    Is it possible to skip the small preview window and the parameters display when i place an iLogic component white the command Place iLogic Component.
    Mvg Jos
    Your drawings are only as good as the symbols that complete them...
    Please use plain text.
    ADN Support Specialist
    Re: place iLogic Component
    01-15-2013 08:38 AM in reply to: j.vanderheijden
    Happy New Year!
    If you don't want the preview window to appear, you don't want the parameters dialog to appear, then the only functionality left is the copying of the file that you want to place.
    You could do that using Windows API or e.g. the ThisApplication.FileManager object
    Then you could just start the component placement command ("Place") of Inventor with the copied part/assembly like shown in this devblog post: http://adndevblog.typepad.com/manufacturing/2013/01/provide-command-parameters-using-postprivateeven...
    In iLogic it would look like this:
    Dim cm As CommandManager
    cm = ThisApplication.CommandManager
    cm.PostPrivateEvent(
    	PrivateEventTypeEnum.kFileNameEvent,
    	"C:\Users\Administrator\Documents\Inventor\TempProject\part - copy.ipt")
    Dim cd As ControlDefinition
    cd = cm.ControlDefinitions("AssemblyPlaceComponentCmd")
    cd.Execute
    I hope this helps.
    Cheers,
    Adam Nagy
    Developer Technical Services
    Autodesk Developer Network
