• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Re: macro/code to export all the parameters information (..)
    05-25-2012 03:34 AM in reply to: yuhanzhang
    It worked ! :smileyvery-happy:
    Thank you so much for your help, once again, without you I wouldn't be able to finish my project !
    JVC
    Please use plain text.
    05-28-2012 01:09 PM in reply to: yuhanzhang
    Hello and sorry for the late response, i had tons of work to do :/
    Yes, the IVB you provided me works really well, thank you!
    But (once again), i just have one more doubt:
    - when you define a hole tolerance as H7 (or other), Inventor automatically sets the upper and lower tolerance values according to the nominal diameter of the hole, right ? So, my question is: when Inventor sets these values, is there a way to access and export them both - H7 and the respective tolerance values (upper and lower) ?
    I'm not sure if I explained myself correctly, but if you can help me or have any questions, feel free to ask them !
    Thank you again,
    Regards
    JVC
    Employee
    05-28-2012 06:28 PM in reply to: joao.av.c
    Sure, the Upper/Lower values are already there and you can export them. See updated attachment.
    Rocky Zhang
    Inventor API
    Manufacturing Solutions
    Autodesk, Inc.
    05-31-2012 04:12 AM in reply to: yuhanzhang
    Hello, and I'm sorrry for the late response !
    It aal works perfectly fine , thank you !
    06-19-2012 04:26 PM in reply to: joao.av.c
    I hope you're doing well.
    Regarding to the previous problem I had, there is a question I sttil have:
    - when modelling a part file in Inventor, only the dimensions we set (dimensions we give a name and a value), are listed in the parameters table. This way, the macro you gave me only exports the information listed in that table.
    - the information listed in the parameters table is based on sketches and features dimensions, as obvious.
    So , my question is: is it possible to access the information (dimension values) contained in a feature (or a sketch) without setting a specific name or value to it?
    For example, in the attached pictures, if a rectangular form is drawn and the dimensions are setted, these will be lisetd in the parameters table (see attached  "pic1" and "pic1 - params").
    But, in the other hand, if the same rectangular form is drawn, but this time without setting any dimension, the parameters table will be empty, obviously (see attached  "pic2").
    After this, i can surely presume that Inventor saves or keeps this information somehow, somewhere, without having to set dimensions or values.
    So, my question is: is it possible to access sketches and/or features information without setting this values?
    I hope i have explained my doubt correctly, if not, let me know!
    My best regards,
    JVC
    Active Contributor wei
    Active Contributor
    10-15-2012 02:30 PM in reply to: joao.av.c
    Hello, Zhang:
    I tried to do as you said, I got a inform " User Defined type not defined"
    What can I do now?
    Thanks!
    Wei
    Employee
    10-21-2012 07:04 PM in reply to: wei
    This sounds like a similiar issue I mentioned above, you should have a proper Excel Object Library referenced for this VBA to work. The attached VBA has the Excel 2010(14.0) referenced, if you have a different Excel version installed you should change it to yours. You can get to the References dialog from Tools->References....
    Hope this helps.
    Rocky Zhang
    Inventor API
    Autodesk, Inc.
