• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    *Pro
    jletcher
    Accepted Solution
    ilogic to count features
    359 Views, 22 Replies
    08-14-2012 01:10 PM
    I have 8 holes each a single feature is there a way for ilogic to count the active ones even if they change to inactive without a ten mile long code?
    Hole 1  true
    Hole 2 true
    Hole 3 true
    Hole 4 False
    Hole 5 False
    Hole 6 False
    Hole 7 true
    Hole 8 true
    Count should be 5
    If I change to
    Hole 1  true
    Hole 2 true
    Hole 3 true
    Hole 4 False
    Hole 5 true
    Hole 6 False
    Hole 7 true
    Hole 8 true
    Count should be 6
    Hole 1  False
    Hole 2 False
    Hole 3 False
    Hole 4 False
    Hole 5 true
    Hole 6 False
    Hole 7 true
    Hole 8 true
    Count should be 3
    Can this be done with short code?
    Many Thanks
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    Please use plain text.
    Valued Contributor
    thomaskennedy
    Re: ilogic to count features
    08-15-2012 01:07 AM in reply to: jletcher
    You can use a For Each Loop to iterate through all the hole features. Something like this should do it :
    NoOfHoles = 0
    For Each HFeature As HoleFeature In ThisDoc.Document.ComponentDefinition.Features.HoleFeatures
    	If HFeature.Suppressed = False Then NoOfHoles = NoOfHoles + 1
    Next HFeature
    MsgBox(NoOfHoles)
    Hope this helps
    Tom
    *Pro
    jletcher
    08-15-2012 04:13 AM in reply to: thomaskennedy
    This gives me an error "end of statement expected"
    James Letcher
    *Pro
    jletcher
    08-15-2012 04:15 AM in reply to: thomaskennedy
    Also this will count all holes right? I only need 8 of the holes to be count if they are active or not if it counts all holes it will give me the wrong count.. Unless I minus the others correct?
    James Letcher
    *Pro
    jletcher
    08-15-2012 04:32 AM in reply to: thomaskennedy
    One more thinfg I want this to go to a ipro in my custom so do I just take out the MsgBox (NoOfHoles)
    and put in the code to fill in my custom iproperty?
    James Letcher
    *Pro
    jletcher
    08-15-2012 06:43 AM in reply to: jletcher
    Autodesk if your not going to step in and help then make samples and help files for ilogic PLEASE.
    James Letcher
    Valued Contributor
    thomaskennedy
    08-15-2012 08:28 AM in reply to: jletcher
    Yes, that code will count all active hole features.
    Yes, change Msgbox(NoOfHoles) to iProperties.Value("Custom", "HoleCount") = NoOfHoles.
    Not sure why your're getting an error, did the code paste correctly into your rule?
    Tom
    ps. There is lots of help and sample code in the 'Programming Help' in Inventor. This is the API help area, which is where you should be looking for this sort of thing.
    Note that the examples are given in VBA but it's easy to convert them for use in iLogic.
    Valued Contributor
    thomaskennedy
    08-15-2012 08:36 AM in reply to: jletcher
    Yes you can subtract a value from the hole count to give you the count you need (if this is workable for you) otherwise you can do some checks against the hole name.
    For example, if you named the holes that need counting "CountMe Hole 1" / "CountMe Hole 2" etc. you could do :
    NoOfHoles = 0
    		If Left(HFeature.Name,7) = "CountMe" Then
    		End If
    	End If
    Next HFeature
    Which will only add the hole to the count if the first 7 chars are "CountMe"
    Valued Mentor
    jdkriek
    08-15-2012 08:37 AM in reply to: thomaskennedy
    I attest to that code working in 2011, 2012, and 2013 iLogic :smileywink:
    Jonathan D. Kriek
    Applications Engineer
    Autodesk Inventor Certified Expert
    Microsoft Certified Application Developer
    _____________________________________________________
    Did I help you? Please choose Accept as Solution or Kudos below
    *Pro
    jletcher
    08-15-2012 08:38 AM in reply to: thomaskennedy
    Well hard to say if it pasted right seeing I don't know what it looks like it copied just like you posted.
    And API is where I try to get help but I am not having much luck converting it to ilogic.
    James Letcher
