ilogic parameter identification
09:37 AM
- Mute
- Permalink
- Report
I have several part models that are very simple and are basically long cylinders. I want to create an external ilogic rule that i can run in each part file that can identify the largest sketch parameter dimension. So basically it will find the Length of the cylinder due to it being a larger dimension and then rename the parameter.
I could just name the cylinder length sketch parameter the same in each part file, but I wanted to attempt to make it more universal for all users. So if a new user forgets to properly label his part parameters, the ilogic program can identify what parameter it should be looking for and rename it properly.
Does anyone have any ideas/tricks to how this can be done?
