Autodesk Inventor Customization
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
ilogic form trigger
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
186 Views, 2 Replies
11-29-2012 03:18 PM
I have a ipt which is controlled via an ilogic form,this form is opened by ilogic code, which in turn is triggered when the ipt is opened.
my problem is when the part is placed within an assembly the said form is triggered and the same happens when the assembly is reopened!.... I would prefer if the form opened only when the ipt is opened or edited....
Is there a snippet of code for this? Or is it even possible?
Re: ilogic form trigger
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-30-2012 06:25 AM in reply to:
Fleagle8t
Try the following code in the rule file that is being opened on open :
Dim CurrentDoc as PartDocument = ThisDoc.Document
If (Not (CurrentDoc Is ThisApplication.ActiveDocument)) Then Return
If my solution seems to remedy your problem, please press the Accept Solution button, -
as it increases my power levels and will eventually help to elevate me towards outer space.
Check out my iLogic injection tool here : http://goo.gl/ce1Qg
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-12-2013 12:24 AM in reply to:
MegaJerk
Works at treat, thanks MegaJerk. ![]()
