Hi!
I have been successful recently in creating a series of rules thanks to the posts of many helpful people, thank you all!
Below are 2 rules that run in succession to create and save a parts list from a base view in a drawing.
I am now trying to set the parts list style to a custom style, ideally while creating the list.
Also, I have to manually go into the list to turn off visibility of certain items (based on material), does anyone know if I can do this with Ilogic? I ask because these steps precede a rule that automates placing base views of all parts in the parts list. If I could get the style and visibility right, I could automate the entire process.
Can anyone help changing such a style with ilogic?
Thanks to all in advance!
Inventor & Vault Pro 2012
Windows 7, 64bit
Core i7 920@2.67
8GB
CREATE PARTS LIST____
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
'Set a reference to the active sheet.
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
' Set a reference to the first drawing view on the sheet. This assumes the first drawing view on the sheet is not a draft view.
Dim oDrawingView As DrawingView
oDrawingView = oSheet.DrawingViews(1)
Dim oPlacementPoint As Point2d
oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(-15#, 20#)
' Create the parts list.
Dim oPartsList As PartsList
'Dim oPartsListStyle As oDrawDoc.StylesManager.PartsListStyle.Name
'oDrawDoc.StylesManager.PartsListStyle.Name = ("CNC Parts List")
oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
iLogicVb.RunRule(export cnc parts list)
EXPORT CNC PARTS LIST____
path_and_name = ThisDoc.PathAndFileName(False) ' without extension
Dim oDoc As Inventor.DrawingDocument
oDoc = ThisDoc.Document
'specify the drawing sheet
oSheet = oDoc.Sheets(1) ' first sheet
' say there is a Partslist on the sheet.
'Dim oPartslist As PartsList
oPartslist = oSheet.PartsLists(1)
' create a new NameValueMap object
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'specify an existing template file
'to use For formatting colors, fonts, etc
oOptions.Value("Template") = ""'"E:\_VAULT WORKING FOLDER\Templates\PARTSLISTEXPORT.xls"
'specify the columns to export
'oOptions.Value("ExportedColumns") = "SYTELINE#;QTY"
'specify the start cell
oOptions.Value("StartingCell") = "A1"
'specify the XLS tab name
'here the file name is used
oOptions.Value("TableName") = "Parts List"
'choose to include the parts list title row
'in this example "Ye Old List of Parts" is written to the StartingCell
oOptions.Value("IncludeTitle") =True
'choose not to autofit the column width in the xls file
oOptions.Value("AutoFitColumnWidth") = False
'choose to apply cell formatting in the xls file
oOptions.Value("ApplyCellFormatting") = True
' export the Partslist to Excel with options
oPartslist.Export (path_and_name & ".xls", PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
And if i want to skip a column in excell, because i have a calcul in???
Hi nealon416,
Here's an example ilogic rule that places a parts list on a specific layer and to a specific style.
I hope this helps.
Curtis
'assumes a drawing document is active. Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument 'Set a reference to the active sheet. Dim oSheet As Sheet oSheet = oDrawDoc.ActiveSheet 'set a reference to the first drawing view on the sheet. Assumes it's not a draft view. Dim oDrawingView As DrawingView oDrawingView = oSheet.DrawingViews(1) 'define the insert point Dim oPlacementPoint As Point2d oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d (27#, 20.625#) 'create the parts list Dim oPartsList As PartsList oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint) 'set parts list to a specific layer oPartsList.Layer = oDrawDoc.StylesManager.Layers.Item("Visible (ANSI)") 'set parts list to a specific style oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("Material List (ANSI)")
Hi sergelachance,
I'm not aware of a way to do this from Inventor. Could you simply move you calculation column and place it to the far right as I've shown in the example at this link?:
http://inventortrenches.blogspot.com/2011/06/ilogic-export-parts-list-with-options.html
If not it might be possible to move the column via some VB magic after the data is exported into the template.
I hope this helps.
Curtis
this is my rule but it's possible to skip a column "k" in excell ???
Sorry for my horrible english 😞 my first language is french
Hi sergelachance,
I don't know how to skip a column. But here is a rule that will write the parts list information to the XLS template, and then cut and insert an existing column with formulas (that is placed to the far right hand column in the template file) to a specific place in the resulting xls.
Template:
Output File:
So as an example, you could move your column K to column Z or some other, and then have the rule cut Column Z and insert it as column K.
You can download the three attached files and place them in the same folder to test this rule.
I hope this helps.
Curtis
Edit the silly face in the code below should be D : D without the spaces
'get the path and name of the drawing file path_and_name = ThisDoc.PathAndFileName(False) ' without extension 'check for existing XLS file and delete it if found if Dir(path_and_name & ".xls") <> "" then Kill (path_and_name & ".xls") else end if 'define oDoc oDoc = ThisDoc.Document 'specify the drawing sheet oSheet = oDoc.Sheets("Sheet:1") ' sheet by name 'oSheet = oDoc.Sheets(1) ' first sheet ' say there is a Partslist on the sheet. oPartslist = oSheet.PartsLists(1) ' create a new NameValueMap object oOptions = ThisApplication.TransientObjects.CreateNameValueMap 'specify an existing template file 'to use For formatting colors, fonts, etc oOptions.Value("Template") = path_and_name & "_template.xls" 'specify the columns to export oOptions.Value("ExportedColumns") = "QTY;PART NUMBER;DESCRIPTION;Length;Width" 'specify the start cell oOptions.Value("StartingCell") = "A1" 'specify the XLS tab name 'here the file name is used oOptions.Value("TableName") = ThisDoc.FileName(False) 'without extension 'choose to include the parts list title row oOptions.Value("IncludeTitle") = False 'choose to autofit the column width in the xls file oOptions.Value("AutoFitColumnWidth") = True ' export the Partslist to Excel with options oPartslist.Export(path_and_name & ".xls", _ PartsListFileFormatEnum.kMicrosoftExcel, oOptions) 'define Excel Application object excelApp = CreateObject("Excel.Application") 'set Excel to run visibly 'change to false if you want to run it invisibly excelApp.Visible = True 'open the workbook wb = excelApp.Workbooks.Open(path_and_name & ".xls") 'cut a column excelApp.Columns("G:G").Cut 'insert the cut column excelApp.Range("D1").Insert 'adjust column width excelApp.Columns("D:D").AutoFit 'reset selected cell to A1 excelApp.Cells(1,1).Select 'suppress prompts (such as the compatibility checker) excelApp.DisplayAlerts = false 'save the workbook wb.Save 'close the workbook, uncomment if you want to close the xls file at the end 'wb.Close
Thanks for your input Curtis... your website has been so important to my success using i-Logic. I appreciate your help!
ALL WORK REALLY GREAT 🙂 IT'S POSSIBLE TO SPECIFY TO EXPORT THE PART LIST IN THE SHEET2 IN THE TEMPLATE???
Hi sergelachance,
I couldn't find a way to specify sheet2 for the export (I might have missed something), but this code can be added to the end to cut the columns from the original exported sheet and paste them to sheet2, and then delete the original sheet. This may or maynot work for you depending on your needs.
I hope this helps.
Curtis
'suppress prompts (such as the compatibility checker) excelApp.DisplayAlerts = False 'select the original exported sheet excelApp.Sheets(ThisDoc.FileName(False)).Select 'select range to copy excelApp.Range("A:G").Copy 'select sheet to paste to excelApp.Sheets("Sheet2").Select 'select range to paste to excelApp.Range("A:G").Select 'paste the selection excelApp.ActiveSheet.Paste 'reset selected cell to A1 excelApp.Cells(1,1).Select 'delete the original sheet excelApp.Sheets(ThisDoc.FileName(False)).Delete() 'save the workbook wb.Save 'close the workbook, uncomment if you want to close the xls file at the end 'wb.Close
Hi Curtis 🙂
I dont use your cut in paste column finaly, work great but the sheet1 is at my cnc, i juste want to choose the sheet2 in my template to export my part list, it's possible???
This is my rule
'define oDoc
'say there is a Partslist on the sheet.
oOptions.Value("Template") = "T:\MasterGDPRO\STYLE_DATA\CARTOUCHE\TEST.xls"
oOptions.Value("ExportedColumns") = "COMPOSANTE;STOCK NUMBER;PI2;LONGUEUR;LARGEUR;QTY;QTE TOTALE;ÉPAISSEUR;CHANTS;DETAIL;COMMANDE;L;M;VEINAGE;USINAGE;NESTING"
oOptions.Value("StartingCell") = "T2"
oOptions.Value("ApplyCellFormatting") = False
Thanks again for all your help 🙂
it's possible to copy iProperties.Value("Custom", "NAME") to sheet2 cell A1?
Thanks for your help 🙂
Export() does not seem to have an option specifying if the data goes on Sheet1 or Sheet2.
Maybe you can specify the sheet name as part of the starting cell. Did you try that?
e.g.: oOptions.Value("StartingCell") = "Sheet2!T2"
However, I guess you could use the Excel API to do post processing on the xls file afterwards.
With the Excel API, you should be able to do any modification on the created xls file.
Cheers,
