iLogic - model or reference parameter
fsanchou
Message 1 of 15
fsanchou
I wish I perform the following code with iLogic.
Is it possible to change a model parameter to a reference parameter?
If My_Expression Then
' My dimension "d0" is a Driven Dimension
' or
' My dimension "d0" is a Reference Parameter
Else
' My dimension "d0" is NOT a Driven Dimension
' or
' My dimension "d0" is a Model Parameter
End If
Replies (14)
Message 2 of 15
Curtis_W
Hi fsanchou,
Here are a couple of examples. The first one gets input from the user:
MyQuestion = MessageBox.Show("Should d0 be Driven? ", "iLogic", MessageBoxButtons.YesNo)
'get the sketch to work with
oSketch = ThisDoc.Document.ComponentDefinition.Sketches.Item("Sketch1")
If MyQuestion = vbYes Then
oSketch.DimensionConstraints.Item(d0).Driven = True
Else
oSketch.DimensionConstraints.Item(d0).Driven = False
End If
 This one simply toggles the driven state:
'toggle from/to driven/driving
If oSketch.DimensionConstraints.Item(d0).Driven = True Then
Else
End If
 I hope this helps.
Curtis
Message 3 of 15
fsanchou
Curtis,
Thank you, this solves exactly my problem.
You are still effective,
Message 4 of 15
fsanchou
Curtis,
I answered a little too quickly without testing your code.
I tried the following code:
ThisDoc.Document.ComponentDefinition.Sketches.Item("Sketch1").DimensionConstraints.Item("d0").Driven = True
I get the following error:
System.Runtime.InteropServices.COMException (0x80020005): Le type ne correspond pas. (Exception from HRESULT: 0x80020005 (DISP_E_TYPEMISMATCH))
   at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
   at LmiRuleScript.Main()
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
In the API Help I found this information :
DimensionConstraints.Item( IndexAs Long ) As DimensionConstraint
NameDescription
IndexInput Long value that specifies the index of the object to return.
I have not found how to find the dimension's index.
Do you have a further response ?
Message 5 of 15
Curtis_W
Hi  fsanchou,
If you remove your dimension name from the quotes does it work then?
You have this:
I think you want this:
ThisDoc.Document.ComponentDefinition.Sketches.Item("Sketch1").DimensionConstraints.Item(d0).Driven = True
I hope this helps.
Curtis
Message 6 of 15
fsanchou
Hi Curtis,
Thanks for your help,
I also tested this solution but it does not work.
d0 return the value of parameter
"d0" is a string
I think I need to find the ID (as long) of the dimension ...
Best regards,
Message 7 of 15
Curtis_W
Hi  fsanchou,
Maybe I'm still not understanding what you're attempting to do.
The previous examples will change d0 to a driven dimension regardless of what the value of that dimension is. Are you needing to know or change the value of d0 also?
I guess I'm not sure why we need the index number when we already know the name of the parameter. Is the name likely to change?, or are you changing it programmatically?
I hope this helps.
Curtis
Message 8 of 15
fsanchou
Hi Curtis,
I am looking to do exactly this code:
Else
End If
 To do that:
But I have this error:
Here the part1.ipt
Message 9 of 15
fsanchou
Hi everyone,
I found :
Dim i As Long
For i = 1 To oSketch.DimensionConstraints.Count
	If oSketch.DimensionConstraints.Item(i).Parameter.Name = "d0" Then
		If oSketch.DimensionConstraints.Item(i).Driven = True Then
		oSketch.DimensionConstraints.Item(i).Driven = False
		Else
		End If
	End If
Next
Thanks Curtis,
Message 10 of 15
hi,
this code can help me too.
so i copy and paste it but it giving me error
Rule Compile Errors in Rule0, in Part3
Error on Line 7 : End of statement expected.
i dont understand
Message 11 of 15
jdkriek
akosi,
The last script posted works for me as well.
Post a screenshot of your iLogic Rule.
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 12 of 15
thanks for immediate response guys...
ive attached a screen shot
inventor 2011
\vault pro 2012
Message 13 of 15
Was there ever an answer to the line 7 error?
I have a need for this code, but I'm getting the same error as above, "line 7".
Message 14 of 15
GosponZ
Rule is working good.
Check parameter to match and sketch# to match. No problem here
Message 15 of 15
Hi akosi,
You probably have already figured this out considering how long ago this post was.
But for your information this used to catch me out alot when copying & pasting ilogic code (Please see below)
Firstly as already mentioned make sure your sketch name matches the sketch you are querying.
Secondly always make sure you re-type the API words (purple words) when copying & pasting sometimes these words don't link/interface with the code.
Hope this helps for any future code writing
Kind Regards
Tim
