- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am working on iLogic rule, part of what I need the rule to do is to change the border on all of the sheets in the current idw. I have seen how to get iLogic to change it on the active sheet, but I am concerned about what will happen on a multi-sheet drawing. So the final piece of the puzzle for my rule is: is there a way to change the borders on all of the sheets with one command or is there a property/variable the that knows how many sheets are in the idw files. I currently have a loop that will cycle through all of the sheets changing the border, so if I figure how to have my rule read that variable/property, I should be in good shape.
Thanks for you help.
Steve
Steve Olson
Manager, Training Services
https://knowledge.autodesk.com/profile/O37DF451BDD2485B
https://www.youtube.com/channel/UCgQTCawsuRFJVSHRXIwLdtg
