• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Valued Contributor
    iLogic form - Show on place component
    74 Views, 1 Replies
    02-22-2012 02:32 PM
    Show on Place Component
    If I set this to true, then when I "place iLogic component", I don't get the form displayed or the parameter table or the model preview.
     Any ideas why?
    If set True, displays the form when placing this model as a component in an assembly. This setting affects Place Component and Place iLogic Component. If the template file has a form, this setting also affects Create In-Place Component.
    Employee
    Re: iLogic form - Show on place component
    02-28-2012 08:08 PM in reply to: DWhiteley
    Can you post a sample part that shows this problem?
    Mike Deck
    Software Developer
    MFG-Digital Engineering
    Autodesk, Inc.
