• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Active Contributor
    OkieWolf
    Re: iLogic Variable Transfer
    02-24-2011 09:06 AM in reply to: OkieWolf
    Mike,
    I found a couple of errors in my code but have now fixed it. However, the rule is unstable. If I start Inventor fresh, open the assembly, and run the rule, it will work most times. Occasionally it won't though, which is really weird. Also, once it has been ran you can't run it again until you close the assembly, reopen it, and run the rule. It is something inside the pipe (If IsPipe....) and/or flange (If IsFlange....) swap "If" that is causing it but I can't figure out what. I've tried resetting all variables to nil once the rule has finished but that doesn't work either. It acts like it is hung up somehow inside the "If" statement because it immediately tries to set the "Parameter(pNewRename, "PL") = OldpLength" and won't even open the dialog before erroring. Below is a picture of what the dialog currently looks like and the updated code is below that.
    Any help is appreciated.
    Rule Code :
    AddReference "NozzleAdjuster1"
    Sub Main
    AddVbFile ("ContentCenterReplace.iLogicVb")
    Dim app As Inventor.Application = ThisApplication
    Dim oDoc As Inventor.AssemblyDocument = app.ActiveDocument
    Dim oCompDef As Inventor.ComponentDefinition = oDoc.ComponentDefinition
    Dim oCompOcc As Inventor.ComponentOccurrence
    For Each oCompOcc In oCompDef.Occurrences
        Dim icompDef as Inventor.ComponentDefinition = oCompOcc.Definition
        Dim icompDoc as Inventor.Document = icompDef.Document
        Dim iPartName As String = System.IO.Path.GetFileNameWithoutExtension(icompDoc.FullFileName)
        iIsPipe = Left(iPartName, 4)
            If iIsPipe = "Pipe" Then
            CurrentSize = Mid(iPartName, 6, 2)
            SizeChk = Mid(CurrentSize, 2, 1)
            pNewNameLength = iPartName.Length
            pNewNameRemainL = pNewNameLength - 7
            pNewNameRemain = Mid(iPartName, 8, pNewNameRemainL)
            pPartName = iPartName & ":1"
            OldPlength = Parameter(pPartName, "PL")
            PipeWall = Parameter(pPartName, "t")
            PipeFlangeOffset = Parameter(oDoc, "d0")
            CurrentNozzleProjection = Parameter(oDoc, "d4")
                If SizeChk = "" Or SizeChk = " " Or SizeChk = nil Then
                CurrentSize = Mid(iPartName, 6, 1)
                pNewNameRemainL = pNewNameLength - 6
                pNewNameRemain = Mid(iPartName, 7, pNewNameRemainL)
                pNewName = iIsPipe & CurrentSize & pNewNameRemain
                End If
            End If
    Next
    Dim dlg as New ClassLibrary1.Dialog1
    dlg.NozzleSize = NozzleSize
    dlg.CurrentSize = CurrentSize
    dlg.PipeWall = PipeWall
    dlg.PipeFlangeOffset = PipeFlangeOffset
    dlg.CurrentNozzleProjection = CurrentNozzleProjection
    dlg.NewNozzleProjection = NewNozzleProjection
    i = dlg.ShowDialog()
    Dim compDef as Inventor.ComponentDefinition = oCompOcc.Definition
    Dim compDoc as Inventor.Document = compDef.Document
    Dim PartName As String = System.IO.Path.GetFileNameWithoutExtension(compDoc.FullFileName)
    Dim replacer As New ContentCenterReplace(ThisDoc.Document, ThisApplication, "en-US")
    Dim PfamilyName As String = "Tube & Pipe:Conduits:smileytongue:ipes:ASTM A 53/A 53M Pipe"
    pCCFam = "ASTM A 53/A 53M "
    Dim FfamilyName As String = "Tube & Pipe:Fittings:Flanges:ASME B16.5 Flange Slip-On Welding - Class 150"
    If IsFlange <> "ASME B16.5 Flange Slip-On Welding - Class 150" Then
    IsPipe = Left(PartName, 4)
    End If
    If IsPipe <> "Pipe" Then
    IsFlange = Left(PartName, 45)
    End If
    If(i = vbOK)Then
    NozzleSize = dlg.NozzleSize
    PipeFlangeOffset = dlg.PipeFlangeOffset
    NewNozzleProjection = dlg.NewNozzleProjection
        If NozzleSize <> "" And NozzleSize <> " " And NozzleSize <> nil Then
            If IsPipe = "Pipe" Then
                pNewName = IsPipe & " " & NozzleSize & " - XS - .001"
                replacer.Replace(pPartName, PfamilyName, pNewName)
                pNewPipeName = pNewName & ":1"
                pNewReName = IsPipe & " " & NozzleSize & " - XS - " & OldPlength & ":1"
                ThisDoc.Document.ComponentDefinition.Occurrences.Item(1).Name = pNewReName
                Parameter(pNewReName, "PL") = OldPlength
            End If
            If IsFlange = "ASME B16.5 Flange Slip-On Welding - Class 150" Then
                fPartName = PartName & ":1"
                NewFlange = IsFlange & " " & NozzleSize
                replacer.Replace(fPartName, FfamilyName, NewFlange)
            End If
        End If
        If PipeFlangeOffset <> "" And PipeFlangeOffset <> " " And PipeFlangeOffset <> nil Then
            Parameter(oDoc, "d0") = PipeFlangeOffset
        End If
        If NewNozzleProjection <> "" And NewNozzleProjection <> " " And NewNozzleProjection <> nil Then
            Parameter(oDoc, "d4") = NewNozzleProjection
        End If
    End If
    Next
    UpdateNozzle
    End Sub
    Sub UpdateNozzle
    InventorVb.DocumentUpdate
    InventorVb.SetViewCamera(ViewCameraOption.FitExtents, New Double() {-121.30039731877672, 145.50927339213723, 145.44114957469338}, New Double() {24.208876073360443, 0, -0.068123817443847656}, New Double() {0.40824829046386318, 0.81649658092772592, -0.40824829046386313}, New Double() {76.824887490943567, 87.260303212016993})
    End Sub
    Please use plain text.
    Employee
    02-24-2011 09:37 AM in reply to: OkieWolf
    Does it always give the same error message?  What is the error message that it gives?
    Did you originally add the pipe as a Custom or Standard component? See the attached picture.
    I thought I could create a test assembly, but it would be better if you could post your assembly.  Also, can you zip up the full VB project for the dialog code and send that?  Or just the .dll file would be enough.
    Mike Deck
    Software Developer
    DLS - Mechanical Design
    Autodesk, Inc.
    Active Contributor
    OkieWolf
    02-24-2011 09:47 AM in reply to: MjDeck
    Yes, it's the same error. See below.
    So, what is happening is that the pipe that's shown in the error is the original pipe (from the first run) before I adjust the length and rename it. But, for some reason it tries to go set that parameter again using the wrong name and even before it opens th dialog.
    And, the pipe was inserted as "Custom" originally.
    Would it be better to just send it to you by email? What's your email?
    Employee
    02-24-2011 11:03 AM in reply to: OkieWolf
    I think I have to change the content center replacer rule to handle Custom components.  That might be required to get your rule working.
     It looks like it is important to you to have the component name reflect the part type and size?  That should be possible, but it makes the rule more complicated.   Would you consider using a component occurrence name that remains constant, such as Pipe:1 or Flange:1?  I know this is not very user-friendly, but it does make the rule simpler.
    My email is mike dot deck at <the company name at the top of this page> dot com
    Mike Deck
    Software Developer
    Autodesk, Inc.
    Active Contributor
    OkieWolf
    02-24-2011 11:11 AM in reply to: MjDeck
    No, it isn't possible for us to use constant naming. We must have the naming as I have it.
    I agree that it would make the rule simpler but we can't at this point.
    The files and a more detailed explanation of what I'm trying to achieve, will be on their way shortly.
    Active Contributor
    OkieWolf
    02-24-2011 12:19 PM in reply to: OkieWolf
    Sent.
    Valued Mentor
    03-14-2011 09:40 AM in reply to: OkieWolf
    Regarding Passing Variables.
    Are you saying the variable CurrentSize is not being passed all the way down to the deepest sub or not being passed back up to the top?
    Arguments in Sub Routines and Functions in VB are passed in one of two ways.  ByRef (By Reference) or ByVal (By Value).
    In effect
    If Passed ByVal they are one way only.  The value is passed into the Sub but not back out.
    If Passed ByRef they are passed two way into and back out of the Sub.
    In iLogic it appears that if you do not specify ByRef or ByVal then ByVal is the Default.
    (This is the opposite from how VBA treats Sub arguments.)
    The following test works fine for me
    Format:HTML Format
    Version:1.0
    StartHTML: 165
    EndHTML: 5252
    StartFragment: 314
    EndFragment: 5220
    StartSelection: 314
    EndSelection: 314
    Sub Main
    Dim CurrentSize As String = "24.375"
    FirstPass(CurrentSize)
    MessageBox.Show("Final Value " & CurrentSize) 'Displays: Final Value 48.625
    End Sub
    Sub FirstPass(ByRef CurrentSize As String)
    SecondPass(CurrentSize)
    End Sub
    Sub SecondPass(ByRef CurrentSize As String)
    MessageBox.show("Deepest Nest " & CurrentSize) 'Displays: Deepest Nest 24.375
    CurrentSize = "48.625"
    End Sub
    Active Contributor
    OkieWolf
    03-14-2011 09:47 AM in reply to: OkieWolf
    That sounds reasonable. However, I have since done away with the subs and just combined all into the main. Is working fine now.
    Active Contributor
    OkieWolf
    03-15-2011 06:40 AM in reply to: OkieWolf
    For anybody that might be following this thread, below is an image of the latest version of the dialog. It's getting really complicated but if I can get everything to work it will be awesome. We are going to convert all of our thousands of 2D AutoCad standard drawings to Inventor 3D models. With this one interface I figure we can eliminate somewhere around 5-6000 2D drawings with one dialog, one internal rule, one external rule (Mike's Content Center Replacer), one assembly, three part files, and one drawing file. That's pretty awesome!! See latest dialog below :
    I do have a question though. In some cases, with smaller nozzles, the repad is not required and it needs to be suppressed. The code snippet in iLogic rules for "IsActive" (true or false) doesn't seem to want to work. I can turn the repad visibility on and off but it needs to be suppressed so that it doesn't show up in the drawing and bill of material.
    Any ideas?
