iLogic-Save as
iLogic-Save as
PJKeeffe
iLogic-Save as
PJKeeffe
The ThisDoc.Document.SaveAs command returns a error message when executed but the message box displays the correct path. ( see attached  .ipt)
Can anybody explain what is going wrong.
Code
Dim mPath As String =iProperties.Value("Custom", "Part Folder") Dim mProj As String =iProperties.Value("Custom", "Project Code") Dim mCall As String =iProperties.Value("Custom", "StairCallout")
Dim nFilename As String = mPath & "\"  & mProj & " Stair " & mCall & "  Stringer.ipt"
MessageBox.Show(nFilename, "Title")
ThisDoc.Document.SaveAs( nFilename , True)
PJKeeffe
I take it that the lack of response from the forum and Autocad Support (Case No:06907388.) there is a issue or bug with ThisDoc.Document.SaveAs  command.  Please advise if so or if possible show where the error is in the code .
thx
