iLogic Rule Suppression
dano0310
dano0310
Just wondering if there is anyway to suppress and unsuppress iLogic Rules from within either the VBA or iLogic itself?
Thanks in advance
Dan
MjDeck
Yes, you can do it in iLogic with this rule statement:
iLogicVb.Automation.GetRule(ThisDoc.Document, "Rule0").IsActive = False
This function will also work from VBA.
Within iLogic, instead of suppressing the rule you could add a conditional statement to the top of the rule to prevent the rule from doing anything:
If (Rule0_ShouldBeSuppressed) Then Return
Here Rule0_ShouldBeSuppressed could be a True/False (Boolean) parameter.  Or you could substitute other logic here.
Mike Deck
Software Developer
Autodesk, Inc.
