iLogic - Rule Driven Assembly - Update Problems
Hi all,
I've come up against a confusing wall in my rule driven assembly, hopefully someone can point out what might be the problem.
The setup is:
I have a rule which first gets a number of user parameters via input boxes.
This rule then runs a number of other rules, using:
iLogicVb.RunRule("Rule 1")
iLogicVb.RunRule("Rule 2")
iLogicVb.RunRule("Rule 3")Each of these rules control parameters, part/feature/constraint suppression etc. in the top level and subassemblies/parts based on the previously obtained user parameters.
All the rules have the 'Don't run automatically' option selected, so all should only run as intended when I manually run the first rule.
When I run the first rule, I enter all the parameters, and the subsequent rules run.
The problem is, the suppression states etc. in the subassemblies/parts do not update.
Looking at the parameters dialog box after the rules have run, all user parameters have updated with the new values.
If I run the first rule again the subassemblies/parts update correctly.
It appears that the rules that control the suppression states etc. of the subassemblies run using the initial values of the user parameters, i.e. the values as they were before the user input is obtained, rather than the new values.
This is confusing me, as the code is structured as follows:
user_parameter_1 = InputBox("User Parameter 1", "Input", "xx")
user_parameter_2 = InputBox("User Parameter 2", "Input", "xx")
iLogicVb.RunRule("Rule 2")Many thanks for any pointers you can offer.
Andy
- Inventor Professional 2011 64Bit SP2 -
