08:42 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to write some ilogic code to set-up the paramaters to median tolerance , then export part in *.step format and save in a specific folder.
I succeed to export files and save it as I want but I can't find the command lines to drive tolerances of parameters (min/max/nominal/median).
Could someone help me or indicate me where to find inventor ilogic command lines... If I-logic could be as easy as VB where it proposed a list of command as you start to typing the function..
Enjoy your Week-end,
John.
