• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Distinguished Mentor
    iLogic Change Sketch Symbol Text Font
    449 Views, 6 Replies
    06-17-2012 10:22 PM
    Hi All,
    My iLogic ability is quite limited outside of what I use regularly, hopefully someone can help?
    I am trying to change the font style in every text definition in all my sketch symbols in one go. Actually I have started it based on only a selection set but I would be happy with just all symbols too. Below is where I got to, I am stuck on the For Each line to cover each text box in the symbol. Some of the other syntax may not be right either but I can't test it all the way through.
    Dim oDoc As DrawingDocument: oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet: oSheet = oDoc.ActiveSheet
    Dim i As Long
    Dim oSymDef As SketchedSymbolDefinition: oSymDef = oDoc.SketchedSymbolDefinitions.Item(i)
    Dim oText As TextBoxes
    For i = 1 To oDoc.SelectSet.Count
    For Each oText In ............
    oSymDef.TextBoxes.Item(i).FormattedText ="<StyleOverride Font='ARIAL'>...< /StyleOverride>"
    Next
    Next
    InventorVb.DocumentUpdate()
    Also the XML style override is not complete if this is the only way to achieve this result.
    Cheers,
    Stew
    Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful.
    Stew, AICP
    Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
    Windows 7 x64 Core i7 32GB Ram FX2000
    Please use plain text.
    Valued Mentor
    jdkriek
    Re: iLogic Change Sketch Symbol Text Font
    06-19-2012 08:51 AM in reply to: Inv_kaos
    You were missing For Each oTextBox In oTextBoxes (Or similar) but that doesn't fix your code.
    Should looks something like this...
    Dim oApp As Application: oApp = ThisApplication
    Dim oDoc As DrawingDocument: oDoc = oApp.ActiveDocument
    Dim oSymbol As SketchedSymbol
    Dim oSymbols As SketchedSymbols
    Dim oSketch As DrawingSketch
    Dim oTextBox As TextBox
    Dim oTextBoxes As TextBoxes
    oSymbols = oDoc.ActiveSheet.SketchedSymbols
        For Each oSymbol In oSymbols
            oSymDef = oSymbol.Definition
            oSymDef.Edit(oSketch)
            oTextBoxes = oSymDef.Sketch.TextBoxes
                    oTextBox.FormattedText = "<StyleOverride Font='ARIAL'>...</StyleOverride>"
                Next
            oSymDef.ExitEdit()
        Next
    You might also look into changing the elements of the text directly?
    oTextBox.Style.Font = "Arial"
    oTextBox.Style.FontSize = 10
    Hope this helps!
    Jonathan D. Kriek
    Inventor Applications Engineer
    Autodesk Inventor Certified Expert
    Microsoft Certified Application Developer
    _____________________________________________________
    Did I help you? Please choose Accept as Solution or Kudos below
    Valued Mentor
    jdkriek
    06-19-2012 09:32 AM in reply to: jdkriek
    Here's an example using the TextStyle - I like this method better
    Dim oStyle As TextStyle
                    oStyle = oTextBox.Style
                    oStyle.Font = "Chiller"
                    oStyle.FontSize = 10
                Next
        Next
    Jonathan D. Kriek
    06-19-2012 06:25 PM in reply to: jdkriek
    Thanks Jon, One problem so far is if the sketch symbol geometry & text has been copied in from AutoCAD I can manually change the font just the same but the code doesn't seem to affect it. Also for Geometry Text there is no change. For everything else this works well. When iLogic was first released free for Inventor there was information in the help files for the Object Library (limited but better than nothing). Is there any way to look up this information now? Otherwise it seems like I have to guess the correct syntax for my code if I can't find a very similar example. Basically there is no intellisense for iLogic so what other options is there for the user? Cheers.
    Stew, AICP
    Valued Mentor
    jdkriek
    06-20-2012 06:54 AM in reply to: Inv_kaos
    It depends on how the AutoCAD text was brought in. Normally I edit the text box in AutoCAD and copy it directly from there, then create a text box in Inventor and paste it directly into it. If it was brought in any other way, then unfortunately that "text" isn't really text, it's rasterized so to speak and can't be changed like normal text at least programmatically.
    About coding: iLogic is essentially VB.NET, so I write all my code in VBA (which has intellisense). All you need to do most of the time is change the syntax a little and boom you have iLogic working. Here's a quick example.
    VBA
    Public Sub VBA()
        Set oApp = ThisApplication
    End Sub
    iLogic (VB.NET)
    iLogic also has the ability to run straight VBA if you don't feel like converting it.
    Just check the box under options when you edit the rule.
    Hope this helps!
    Jonathan D. Kriek
    06-21-2012 09:52 PM in reply to: jdkriek
    These are all weld details that have been copied from AutoCAD (lines, dimensions & text), we have not copied just the text in one go. It still works fine like most text brought in from ACAD but I guess we will just have to modify it all manually. Thanks for the help. I have been working in Visual Studio a bit recently but need more practice. Even though it is simplified VB.NET I still see more parallels with VBA.
    Stew, AICP
    Valued Contributor
    02-01-2013 02:57 AM in reply to: Inv_kaos
    it's possible to specify the number of caracter of texte?
    ex.: if "parameter" if more than 20 caractere then
