how to know if a view is baseview with vb.net?
While loop through all Views in a sheet, I can use oView.ScaleFromBase to know if the scale of the view is changed from Base-View. Like this:
  For Each oView In oViews
                If oView.ScaleFromBase = False Then
'This view's scale is different from that of the Base-View
 But I can't tell in this way if it is a Base-View or views with different view scale.
There is a oView.ViewType,  I tried this
Dim mytype As String
mytype = oView.ViewType
for Base-View, mytype=10501
for other-view with different scale, mytype=10504
Is there other property I could use? Can't work out how to get the View Type Name.
Thanks for help.
Peter
Vladimir.Ananyev
You may check oView.ParentView property.
For base view it returns Nothing.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Hi Vladimir,
I tried this, but both baseview and view whose scale if different from baseview return a Nothing.
Peter
            Dim myView As DrawingView
                    myView = oView.ParentView
                    If myView Is Nothing Then
                        MsgBox("nothing")
                    Else
                        MsgBox("something")
                    end if
                 end if
             next
YuhanZhang
Can you attach the data that you see the problem? Or double check the drawing view which has different scale from its parent view does have a parent view or not?
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
You can check this way:
For each oView in oViews
     If oView.ViewType = Inventor.DrawingViewTypeEnum.kStandardDrawingViewType Then
          Debug.Print("This is a base view")
     Else
          Debug.Print("This is not a base view")
     End If
Next
 Or you can check the oView.Aligned property but this will also return false if the alignment has been broken from the base view.
Hi Rocky,
I just made a cube and generated a base view, a top view,a right view and an iso view. Then I change the view scale of the iso view.
Then I want the code to tell me which one's scale is changed and it is not a base view.
Peter
Hi Robert,
It's works for me. thank you very much.
Peter
