• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Active Contributor
    Accepted Solution
    how to know if a view is baseview with vb.net?
    84 Views, 6 Replies
    02-05-2013 03:01 AM
    While loop through all Views in a sheet, I can use oView.ScaleFromBase to know if the scale of the view is changed from Base-View. Like this:
      For Each oView In oViews
                    If oView.ScaleFromBase = False Then
    'This view's scale is different from that of the Base-View
     But I can't tell in this way if it is a Base-View or views with different view scale.
    There is a oView.ViewType,  I tried this
    Dim mytype As String
    mytype = oView.ViewType
    for Base-View, mytype=10501
    for other-view with different scale, mytype=10504
    Is there other property I could use? Can't work out how to get the View Type Name.
    Thanks for help.
    Peter
    Please use plain text.
    ADN Support Specialist
    Re: how to know if a view is baseview with vb.net?
    02-05-2013 07:00 AM in reply to: shirazbj
    You may check oView.ParentView property.
    For base view it returns Nothing.
    Vladimir Ananyev
    Developer Technical Services
    Autodesk Developer Network
    Active Contributor
    02-05-2013 04:47 PM in reply to: Vladimir.Ananyev
    Hi Vladimir,
    I tried this, but both baseview and view whose scale if different from baseview return a Nothing.
    Peter
                Dim myView As DrawingView
                        myView = oView.ParentView
                        If myView Is Nothing Then
                            MsgBox("nothing")
                        Else
                            MsgBox("something")
                        end if
                     end if
                 next
    Employee
    02-06-2013 01:48 AM in reply to: shirazbj
    Can you attach the data that you see the problem? Or double check the drawing view which has different scale from its parent view does have a parent view or not?
    Rocky Zhang
    Inventor API
    Manufacturing Solutions
    Autodesk, Inc.
    robert.ferguson
    02-07-2013 07:13 AM in reply to: shirazbj
    You can check this way:
    For each oView in oViews
         If oView.ViewType = Inventor.DrawingViewTypeEnum.kStandardDrawingViewType Then
              Debug.Print("This is a base view")
         Else
              Debug.Print("This is not a base view")
         End If
    Next
     Or you can check the oView.Aligned property but this will also return false if the alignment has been broken from the base view.
    Active Contributor
    02-08-2013 03:44 PM in reply to: yuhanzhang
    Hi Rocky,
    I just made a cube and generated a base view, a top view,a right view and an iso view. Then I change the view scale of the iso view.
    Then I want the code to tell me which one's scale is changed and it is not a base view.
    Peter
    Active Contributor
    02-08-2013 03:45 PM in reply to: robert.ferguson
    Hi Robert,
    It's works for me. thank you very much.
    Peter
