face.CalculateFacetsAndTextureMap throw exception
pfk
pfk
Hi
I have a valid Face from a SurfaceBody, and the call to face.CalculateFacetsAndTextureMap throws the following exception....
[System.Runtime.InteropServices.COMException] = {"Type mismatch. (Exception from HRESULT: 0x80020005 (DISP_E_TYPEMISMATCH))"}
The code I'm using is:
                foreach (Face face in surfaceBody.Faces)
                    double tolerance = 0.1;
                    int vertexCount = 0;
                    int facetCount = 0;
                    double[] vertexCoordinates;
                    double[] normalVectors;
                    int[] vertexIndexes;
                    double[] textureCoordinates;
                    face.CalculateFacetsAndTextureMap(tolerance, out vertexCount, out facetCount, out vertexCoordinates, out normalVectors, out  vertexIndexes, out textureCoordinates);
 Can anyone guide to me what I am doing wrong pls?
adam.nagy
Autodesk Support
Autodesk Support
You would need to initialize the input arrays: http://adndevblog.typepad.com/manufacturing/2013/05/type-mismatch-when-calling-calculatefacetsandtex...
Cheers,
Adam Nagy
Autodesk Platform Services
pfk
I confirm that this fixes the issue.  Thank you so much for taking the time to add a blog entry on this.  A reminder for other people implementing this function, the vertex indexes start at 1, not 0 (this is in the documentation, but easy to miss).
