Autodesk Inventor Customization
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
change browser folder icon
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
is it possible to change browser folder icon?
Re: change browser folder icon
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm not sure I understand the question. The folder icon of what and where exactly?
I think it would be useful to provide an image of what the current situation is vs. what you'd like to get.
Cheers,
Adam Nagy
Developer Technical Services
Autodesk Developer Network
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please find attached, The browser folder inside assembly document, To replace the standard icon with a custom icon
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Changing the icon of a native browser node is similar to setting the icon of your own panel's client node, but you work with NativeBrowserNodeDefinition and set the OverrideIcon property instead.
Sub ChangeIcon()
Dim bps As BrowserPanes
Set bps = ThisApplication.ActiveDocument.BrowserPanes
' e.g. if you want to change the root node's icon
' in the assembly "Model" panel
Dim bp As BrowserPane
Set bp = bps("AmBrowserArrangement")
Dim bmp As IPictureDisp
Set bmp = LoadPicture("C:\Bitmap1.bmp")
Dim cnr As ClientNodeResource
' Only Bitmaps are supported by the Add method
' and it should be 16x16
Set cnr = bps.ClientNodeResources.Add( _
"MyResource", 2, bmp)
Dim nbnd As NativeBrowserNodeDefinition
Set nbnd = bp.TopNode.BrowserNodeDefinition
nbnd.OverrideIcon = cnr
End Sub
I hope this helps.
Cheers,
Adam Nagy
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Gives Add Method Error. See Attachment
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I believe this code is unlikely to succeed on 64-bit because VBA is running out of process. You would need either to use 32-bit VBA or try the same from a VB.Net/C# add-in. The way to load resources if different however in .Net.
You can refer to the following articles:
http://adndevblog.typepad.com/manufacturing/2012/0
Philippe.
Philippe Leefsma
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Attached is an iLogic rule that will work for an assembly or part document.
Mike Deck
Software Developer
DLS - Mechanical Design
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
