adding a sub-component as a participant in an assembly feature in iLogic/API
MikeGillam5072
MikeGillam5072
Is there a trick to making a sub-component participate in a feature (ExtrudeFeature, SweepFeature, etc.)?
I've tried using the SweepFeature.AddParticipant(ComponentOccurrence) and ExtrudeFeature(ComponentOccurrence) functions, and both work fine when the ComponentOcurrence is a direct component of the assembly.
However, if I explode down another level, and pass in a ComponentOccurrence for a sub-component, I get an INVALID_ARG error.
I can do this manually in the Inventor model browser.
I worked around the problem by collapsing the assembly structure, but now my customer is pressing me "to do it right".
If necessary, I'll reconstruct a the code snippet that was failing.
Any help is appreciated.  thanks
YuhanZhang
Below sample will show how to implement it:
Sub AddParticipantSample()
    ' New an assembly, place a sub-assembly which has two occurrences
    ' create an extrude feature on the first occurrence of the sub-assembly
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oExtrude As ExtrudeFeature
    Set oExtrude = oDoc.ComponentDefinition.Features.ExtrudeFeatures(1)
    Dim oOcc As ComponentOccurrence
    Set oOcc = oDoc.ComponentDefinition.Occurrences(1)
    Dim oSubOccProxy As ComponentOccurrenceProxy
    oOcc.CreateGeometryProxy oOcc.SubOccurrences(2), oSubOccProxy
    oExtrude.AddParticipant oSubOccProxy
End Sub
 You may want to see a topic in API document titled "Introduction to proxies", it will explain the concept of proxy. Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
