• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Accepted Solution
    VBA or VB for sculpting overlapping objects in an Assembly??
    189 Views, 6 Replies
    10-19-2012 09:06 AM
    Hi
    I have an assembly with various parts in it.  I am trying to write a routine that will
    1) systematically traverse the assembly and find parts that overlap,
    2) where they overlap perform a sculpt operation on the parts
    Whilst i can do this manually by edit>copy object>sculpt>select surface ...  i don't know how to mimic this programmatically.
     So far i have coded to do it in a very hamfisted way by making a derived part file from the overlapping parts, opening the derived part file and performing the sculpt, replacing the original part in the assembly with its new derived-sculpted part and then continuing to traverse the assembly tree..  - it is super slow and uses lots of file operations.
    Does anyone have any examples of a slick way to do this??
    Thanks in advance
    regards
    Dan
    Please use plain text.
    Valued Mentor
    jdkriek
    Re: VBA or VB for sculpting overlapping objects in an Assembly??
    10-19-2012 12:20 PM in reply to: mitcham_boy
    The derive-sculpt method that you described is the only way I'm aware of.
    For a better solution I'm afraid we need more exposed to the API.
    Jonathan D. Kriek
    Inventor Applications Engineer
    Autodesk Inventor Certified Expert
    Microsoft Certified Application Developer
    _____________________________________________________
    Did I help you? Please choose Accept as Solution or Kudos below
    10-22-2012 02:16 AM in reply to: jdkriek
    Jonathan
    Thank you for your very quick reply.
    I am gleaning most of what i can from the VBA f1 help, these forums and some very useful presentations by Brian Ekin on the AutoDesk website - is there a recommended book on programming the API that walks through all the geometric/file based/etc operations with examples?
    thanks again
    Dan.
    10-22-2012 03:27 AM in reply to: mitcham_boy
    Hi Jonathan
    I had been hoping to use the SculptFeatures method on a transient surface collection object instead of the derive-sculpt but i can't quite get the hang of the surface objects, can you see what i am doing wrong? :
    For example: i have an assembly containing a pipe and a small block that overlaps the pipe.  I want to remove the small block from the pipe wall.
    ofilePipe is the part document for the pipe.
    ofileBlock is the part document for the block
    So i want to use the following 'SculptFeatures' method passing it a surfaces collection which is the surface bodies of both the pipe and block... Call ofilePipe.ComponentDefinition.Features.SculptFeatures.Add(mySurfaces, False) where true adds material, false removes material.  So to use the above i create a transient object collection named mySurfaces containing the surface bodies from each part...  But it falls over at the line which is bold italic because there's something wrong with my attempt to obtain the surfaces of a part.
       Dim mySurfaces As ObjectCollection
       Set mySurfaces = ThisApplication.TransientObjects.CreateObjectCollection
       Dim mySculptPipe As SculptSurface
       Dim mySculptBlock As SculptSurface
       Set mySculptPipe = ofilePipe.ComponentDefinition.Features.SculptFeatures.CreateSculptSurface(myPipe.SurfaceBodies.Item(1))  'get the pipe part's surfaces as a surface object
       Set mySculptBlock = 'ditto but for the block part
       Call mySurfaces.Add(mySculptPipe) ' add the pipe surface object to the collection
       Call mySurfaces.Add(mySculptBlock) 'add the block surface object to the collection
       Debug.Print "all surfaces added to transient object collection."
       Call ofilePipe.ComponentDefinition.Features.SculptFeatures.Add(mySurfaces, False) 'true adds material, false removes material
       Debug.Print "sculpt operation performed to original part document without requirement for derived part files."
    Can you advise what i'm doing wrong?
    thanks and regards
    Dan
    Valued Mentor
    jdkriek
    10-25-2012 07:22 AM in reply to: mitcham_boy
    Hi Dan,
    Where is myPipe defined?
    Can you post all of the code?
    Jonathan D. Kriek
    10-26-2012 01:16 AM in reply to: jdkriek
    Sure, full code below:...
    Sub for_furtherwork()
      Dim myPipe As ComponentOccurrence
      Dim myBlock As ComponentOccurrence
      Set myPipe = ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.Item(1)
      Set myBlock = ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.Item(2)
    Debug.Print myPipe.Name
    Debug.Print myBlock.Name
      Dim ofilePipe As PartDocument
      Set ofilePipe = myPipe.Definition.Document
      'Set mySculptBlock = ofilePipe.ComponentDefinition.Features.SculptFeatures.CreateSculptSurface(myBlock)
      Call ofilePipe.ComponentDefinition.Features.SculptFeatures.Add(mySurfaces, False) 'False removes material
    Debug.Print "sculpt operation performed."
    End Sub
    11-29-2012 08:40 AM in reply to: mitcham_boy
    I have found the following solution courtesy of Brian Eakin's "API 2011 What's New" .ivb example modules
    Clearly it is only valid for 2011 onwards.
    ' The following sample demonstrates associatively copying bodies across parts
    ' in an assembly.  Before running this sample open the sample assembly called
    ' CutExample.iam.  It can be run on any assembly that contains two parts, but
    ' the sample demonstrates a common use of the functionality.  The use in this
    ' case is to use one part to cut another one, where the positions of the parts
    ' are the defined in the assembly but the cut is performed within the part and
    ' not as an assembly feature.
    Sub AssociativeBodyCopy()
        ' Open the existing sample assembly.
        Dim assemblyDoc As AssemblyDocument
        Set assemblyDoc = ThisApplication.ActiveDocument
        Dim assemblyDef As AssemblyComponentDefinition
        Set assemblyDef = assemblyDoc.ComponentDefinition
        ' Get the first occurrence, which will be treated as the base part.
        Dim baseOcc As ComponentOccurrence
        Set baseOcc = assemblyDef.Occurrences.Item(1)
        ' Get the second occurrence, which will be used as the cut tool.
        Dim toolOcc As ComponentOccurrence
        Set toolOcc = assemblyDef.Occurrences.Item(2)
        ' Get the component definition of the base part.
        Dim baseDef As PartComponentDefinition
        Set baseDef = baseOcc.Definition
        '** Create an associative surface base feature in the second part.
        ' Create a definition object in the context of the first part.
        Dim baseFeatureDef As NonParametricBaseFeatureDefinition
        Set baseFeatureDef = baseDef.Features.NonParametricBaseFeatures.CreateDefinition
        ' Add the body of the second part to the list of items to be copied.  Since this
        ' is getting the body from the occurrence it is actually a SurfaceBodyProxy
        ' object in the context of the assembly.
        Dim bodyColl As ObjectCollection
        Set bodyColl = ThisApplication.TransientObjects.CreateObjectCollection
        bodyColl.Add toolOcc.SurfaceBodies.Item(1)
        ' Set up the definition object.  When setting the IsAssociative flag to True, the
        ' Output type must be either a Surface or Composite.  A solid is not valid in that case.
        baseFeatureDef.BRepEntities = bodyColl
        baseFeatureDef.OutputType = kSurfaceOutputType
        baseFeatureDef.TargetOccurrence = baseOcc
        baseFeatureDef.IsAssociative = True
        ' Create the associative copy.
        Dim baseFeature As NonParametricBaseFeature
        Set baseFeature = baseDef.Features.NonParametricBaseFeatures.AddByDefinition(baseFeatureDef)
        assemblyDoc.Update
        ' Get the WorkSurface that was created as a result of the import.
        Dim surface As WorkSurface
        Set surface = baseFeature.SurfaceBody.Parent
        ' Split the base part using the new surface.
        Call baseDef.Features.SplitFeatures.TrimSolid(surface, baseDef.SurfaceBodies.Item(1), False)
        ' Turn off the visibilty of the work surface.
        surface.Visible = False
        ThisApplication.ActiveView.Update
    End Sub
