• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Valued Mentor
    VBA automation of iLogic External Rule Fails.
    225 Views, 1 Replies
    03-21-2011 10:52 AM
    Error says cannot find the External Rule in the current Document.
    Is there some way I can tell the iLogicAuto.Getrule(doc, "RunDll_Test") method that the rule is external and not inside the current document?
    Please use plain text.
    Employee
    Re: VBA automation of iLogic External Rule Fails.
    03-24-2011 08:30 AM in reply to: Gruff
    The GetRule function will only work on internal rules.
    Do you want to run the external rule?  If so, use the function:
    iLogicAuto.RunExternalRule(doc, fileName)
    fileName can be a relative or absolute path name.
    Mike Deck
    Software Developer
    DLS - Mechanical Design
    Autodesk, Inc.
