VBA - adding custom command to context menu
How can I add custom command (macro) to a context menu in Inventor 2010 via VBA?
(I searched the forum and got it to the point when I'm able to add commands that are built in Inventor)
The example how to do it would be the best solution
Thx
xiaodong_liang
Autodesk Support
Autodesk Support
In the previous releases, the linear MarkingMenu and RadialMarkingMenu are not introduced. UsertInputEvents. OnContextMenu is to customize the context menu. The structure of VBA code is as below.
' *************module*****************
Sub test()
Dim oC As clsUserInput
Set oC = New clsUserInput
oC.Initialize
Do While True
  DoEvents
Loop
End Sub
******class: clsUserInput *********
Option Explicit
Private WithEvents oUserInputEvents As UserInputEvents
Private WithEvents oCtrlDefNew As ButtonDefinition
Public Sub Initialize()
Set oUserInputEvents = ThisApplication.CommandManager.UserInputEvents
End Sub
Private Sub oUserInputEvents_OnContextMenu(ByVal SelectionDevice As SelectionDeviceEnum, ByVal AdditionalInfo As NameValueMap, ByVal CommandBar As CommandBar)
On Error Resume Next
' Check if the context menu has the 'Home View' (formerly 'Isometric View') command
Dim oCmdBarControl As CommandBarControl
Set oCmdBarControl = CommandBar.Controls.Item("AppIsometricViewCmd")
If Not oCmdBarControl Is Nothing Then
'Dim oCtrlDefNew As ButtonDefinition
Set oCtrlDefNew = ThisApplication.CommandManager.ControlDefinitions.AddButtonDefinition("MyContextMenu", _
"MyContextMenu", kShapeEditCmdType, "", "MyContextMenu", "MyContextMenu")
If oCtrlDefNew Is Nothing Then
Set oCtrlDefNew = ThisApplication.CommandManager.ControlDefinitions("MyContextMenu")
End If
Call CommandBar.Controls.AddButton(oCtrlDefNew, oCmdBarControl.index)
End If
End Sub
Public Sub oCtrlDefNew_OnExecute(ByVal Context As NameValueMap) ¡®event of button
oCtrlDefNew.Pressed = Not oCtrlDefNew.Pressed ¡®pressed or un-pressed
MsgBox "my button is clicked"
End Sub
Now, you will need to use
 UsertInputEvents. OnLinearMarkingMenu
UsertInputEvents. OnRadialMarkingMenu
UsertInputEvents. OnContextualMiniToolbar
The code demo is as below:
Sub test()
Dim oC As Class1
Set oC = New Class1
oC.ini
Do While True
  DoEvents
Loop
End Sub
'*********** event *****************
Private WithEvents oUE As UserInputEvents
Public Sub ini()
Set oUE = ThisApplication.CommandManager.UserInputEvents
End Sub
Private Sub oUE_OnLinearMarkingMenu(ByVal SelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal LinearMenu As CommandControls, ByVal AdditionalInfo As NameValueMap)
       ' Check to see if a single planar face is selected.
    If SelectedEntities.Count = 1 Then
        If TypeOf SelectedEntities.Item(1) Is Face Then
            Dim oFace As Face
            Set oFace = SelectedEntities.Item(1)
            If oFace.SurfaceType = kPlaneSurface Then
               Call LinearMenu.AddButton(ThisApplication.CommandManager.ControlDefinitions("mycommand_internalname"), True)
            End If
        End If
    End If
     Set oUE = Nothing  'stop the events
End Sub
