• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Valued Contributor
    Accepted Solution
    VB to change Custom Table Title and Header Cell / Row Height
    234 Views, 2 Replies
    09-06-2012 12:38 PM
    When you make a custom table in VB.net, adding in the Row Height property in the custom table create line only changes the data cell row heights, not the title cells or the header cell.  How do yo do set the title/header cell row heights ?
    Dim oRowHeights_FS(11) As Double
    oRowHeights_FS(0) = 0.6
    oRowHeights_FS(1) = 0.6
    oRowHeights_FS(2) = 0.6
    oRowHeights_FS(3) = 0.6
    oRowHeights_FS(4) = 0.6
    oRowHeights_FS(5) = 0.6
    oRowHeights_FS(6) = 0.6
    oRowHeights_FS(7) = 0.6
    oRowHeights_FS(8) = 0.6
    oRowHeights_FS(9) = 0.6
    oRowHeights_FS(10) = 0.6
    oRowHeights_FS(11) = 0.6
    Dim position_FrameShear As Point2d = _invApp.TransientGeometry.CreatePoint2d((oInvSheet.Border.RangeBox.MinPoint.X + 16), (oInvSheet.Border.RangeBox.MaxPoint.Y))
    Dim oCustomTable_FrameShear As CustomTable
    oCustomTable_FrameShear = oInvSheet.CustomTables.Add(vValue_FrameType & " " & vValue_Hand & " Frame Shear List", position_FrameShear, 6, 12, oTitles_FrameShear, oContents_FrameShear, oColumnWidths_FrameShear, oRowHeights_FS)
    Please use plain text.
    ADN Support Specialist
    xiaodong.liang
    Re: VB to change Custom Table Title and Header Cell / Row Height
    09-11-2012 06:26 PM in reply to: nickv02
    hi,
    you will need to set the table style. e.g.
    Public Sub CreateCustomTable()
        ' Set a reference to the drawing document.
        ' This assumes a drawing document is active.
        Dim oDrawDoc As DrawingDocument
        Set oDrawDoc = ThisApplication.ActiveDocument
        ' Set a reference to the active sheet.
        Dim oSheet As Sheet
        Set oSheet = oDrawDoc.ActiveSheet
        ' Set the column titles
        Dim oTitles(1 To 3) As String
        oTitles(1) = "Part Number"
        oTitles(2) = "Quantity"
        oTitles(3) = "Material"
        ' Set the contents of the custom table (contents are set row-wise)
        Dim oContents(1 To 9) As String
        oContents(1) = "1"
        oContents(2) = "1"
        oContents(3) = "Brass"
        oContents(4) = "2"
        oContents(5) = "2"
        oContents(6) = "Aluminium"
        oContents(7) = "3"
        oContents(8) = "1"
        oContents(9) = "Steel"
        ' Set the column widths (defaults to the column title width if not specified)
        Dim oColumnWidths(1 To 3) As Double
        oColumnWidths(1) = 2.5
        oColumnWidths(2) = 2.5
        oColumnWidths(3) = 4
          Dim oRowHeights_FS(2) As Double
    oRowHeights_FS(0) = 1
    oRowHeights_FS(1) = 1
    oRowHeights_FS(2) = 1
         oDrawDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.TableStyle.HeadingGap = 1
        ' Create the custom table
        Dim oCustomTable As CustomTable
        Set oCustomTable = oSheet.CustomTables.Add("My Table", ThisApplication.TransientGeometry.CreatePoint2d(15, 15), _
                                            3, 3, oTitles, oContents, oColumnWidths, oRowHeights_FS)
    End Sub
    Xiaodong Liang
    Developer Technical Services
    Autodesk Developer Network
    Valued Contributor
    10-02-2012 09:43 AM in reply to: xiaodong.liang
    Finally got around to trying this and it does indeed work, thank you.
    Wanted to add for future reference that my initial thought was setting the number would be the actual row height, when indeed, as the code states, it's a gap, so it's the space around the text in the column heading.  I set it to .150  and it worked great.
    oDrawDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.TableStyle.HeadingGap = 0.150
