Using Rules to replace a subassembly
I have a top level assembly that consists of two sub assemblies, one that has two variations, one that has 3 variations.  I want to swap the subassemblies based on conditions that are set up in a linked Excel Spreadsheet.  In other words, based on certain factors defined in the spreadsheet I want to swap the sub assemblies with other subassemblies that have been updated to meet the criteria specified in the spreadsheet.
you can use the Component.Replace function
if paramA = 1 then
Component.Repace("initial subassembly", " new  subassembly.iam",False)
end if
You need to stabalize  the initial subassembly name in the Inv browser
False replaces the first occurence, use True to replace all occurences
The initial subassembly must be placed using imates and the new subassenbly must have matching imates for the replace to work properly
"You need to stabalize  the initial subassembly name in the Inv browser
The initial subassembly must be placed using imates and the new subassenbly must have matching imates for the replace to work properly"
Can you explain what you mean by Stabalize the initial subassembly name?  I'm also a little unclear on the difference between False and True.  If the subassembly occurs only once in the assembly I am to use "False"?  I have two subassemblies, one called "Master Chamber_With Tabs.iam" and one called "Master Chamber_With Tabs_Half Wall.iam".  I want to automatically replace one with the other when certain values in the spreadsheet are true.  So I am to prepare the rule like the following:
Component.Replace("Master Chamber_With Tabs:1", "Master Chamber_With Tabs_Half Wall.iam", False)
okay, lets look at your code
when the code runs the first time Master Chamber_With Tabs:1 would be replaced, however if you ran the code a second time it would fail since Master Chamber_With Tabs:1 will not be found (since it has been replaced)
Therefore you have to "stabalize"  the occurence name
Do this
Assemble Master Chamber_With Tabs:1 into your upper level assembly
find Master Chamber_With Tabs:1 in your Inventor browser , and rename it to something else meaningful like Master Chamber Option:1
then change your rule to read
Component.Replace("Master Chamber Option:1", "Master Chamber_With Tabs_Half Wall.iam", False)
then your code will work every time since it will always find the "stabalized" occurence name
if you only have one occurance of the sub assembly then either True or False will do the same thing
It only makes a difference if you have multiple instances and want to control only certain ones
This worked perfectly, thank you.
