• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor Customization
    Member
    nick801
    TitleBlock iProperties
    271 Views, 0 Replies
    04-19-2011 03:49 AM
    I made a VBA macro with Inventor 10 to create title blocks with custom properties. The same title blocks were exported to AutoCAD 2007 and worked very well.
    We are currently using Inventor 2010 and 2011. The VBA macro and thus generated Title blocks work with Inventor Perfectly.
    If the Title blocks are saved in dwg format and edited with AutoCAD 2007(2010/2011), then you realize that the attribute information was lost.
    For testing, I created the custom properties manually and exported to dwg. These blocks kept the attribute information.
    I compared the formatted text of custom properties of the two title blocks (manual and by VBA-macro ) and they are completely identical.
    It worked once and now it no longer runs.
    Can somebody help?
    Tested on:
    HP 6600/ XP 32-bit / Inventor 2010 / AutoCAD 2007/2010
    HP Z600/XP 64-bit / Inventor 2010/2011 / AutoCAD 2008/2010/2011ANGM1989
    Nick
    Please use plain text.
