Title Block - Copyright Year
Hey Everyone,
So, I am trying to add a copyright year to a title block in a drawing template file used through out my company. I want to base the year off of the creation date property - I am trying to find a way to truncate this property such that only the year is displayed. Ideally, any time the creation date property is changed, the copyright year will also update.
We are currently running Inventor 2010.
My thoughts:
Normally, I would just write an iLogic rule with an event trigger, but this would require everyone to install the iLogic addin which just won't happen.
Even easier, I could make a custom iProperty and just have people manually type in the year when they start a new drawing - this will be worst case scenario as a ton of people will forget and I'll just make more work for myself.
I also have VBA code which is pretty simple:
Public Sub SetYear()
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
Dim customPropSet, customPropSet2 As PropertySet
Set customPropSet2 = oDoc.PropertySets.Item("Design Tracking Properties")
Set customPropSet = oDoc.PropertySets.Item("Inventor User Defined Properties")
Dim customProp, creationDate As Property
Set customProp = customPropSet2.Item(1)
Set creationDate = customPropSet.Item("CreationYear")
Dim year, newYear, newerYear As String
year = customProp.Value
Dim count As Integer
count = InStr(year, " ")
newYear = Left(year, count - 1)
newerYear = Right(newYear, 4)
creationDate.Value = newerYear
oDoc.Update
End Sub
The issue would be getting this VBA code to trigger and to "stick" to the template file.
I can just as easily write this code in VB.NET or C#, and go through the hassle of creating an add-in, but again, how would I get it to trigger and stick to the template file.
With that being said, if any one can provide suggestions to my current thoughts or any alternatives, it would be greatly appreciated. Thank you!
VdVeek
Have a look at Now. Hope this is the right direction for you. Don't have time now to search better, but this could help you.
iProperties.Value(“Project”, “Project”) = Now.ToString(“dd-mm-yyyy”) ‘Set Project to today’s date 04-08-2012
‘hh = 10 HH = 22
‘mm = 53
‘ss = 23
‘dd-mm-yyyy = 04-08-2012
‘d/m/yy = 4/8/12
‘MMMM = augustus
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
Hi Bennywise578,
To get your code to fire within the template, you need to add it to the template file. To get it to fire at some event, you need to create the ApplicationEvents bits and bobs. This is great if you only have a single template file (stored on a network rather than lots of local templates).
Also to get the year, you can simply use VBA.Format(VBA.Date,"yyyy").
The code below should update your CreationDate iProp when saved (you can change this it on new if you wish) - i've not had chance to test it...
Hope this helps.
Regards
Jon
Option Explicit
Private WithEvents oApplicationEvents As ApplicationEvents
Private Sub Class_Initialize()
  Set oApplicationEvents = ThisApplication.ApplicationEvents
End Sub
Private Sub Class_Terminate()
  Set oApplicationEvents = Nothing
End Sub
'Then you need to create an instance of this class so that
'the event is reacted to e.g.
Option Explicit
Dim oEventHandler As MyEventHandler
Sub listenToEvents()
  Set oEventHandler = New MyEventHandler
End Sub
Sub stopListening()
  Set oEventHandler = Nothing
End Sub
Private Sub oApplicationEvents_OnSaveDocument(ByVal DocumentObject As Document, _
                                            ByVal BeforeOrAfter As EventTimingEnum, _
                                            ByVal Context As NameValueMap, _
                                            HandlingCode As HandlingCodeEnum)
'    Dim year, newYear, newerYear As String
'    year = customProp.Value
'    Dim count As Integer
'    count = InStr(year, " ")
'    newYear = Left(year, count - 1)
'    newerYear = Right(newYear, 4)
    creationDate.Value = Format(VBA.Date, "yyyy")
    oDoc.Update
End Sub
So this is what I ended up doing:
In the document project, in the "ThisDocument" file, I put the following code:
Public Sub AutoSave()
Call setYear
End Sub
And in Module1 file (in the document project), I put the following code:
Public Sub setYear()
    Dim year, newYear, newerYear As String     year = customProp.Value
    Dim count As Integer     count = InStr(year, " ")
    oDoc.Update
End Sub
Everytime I save the drawing, the custom iProperty "CreationYear" is set to just the year of the Creation Date iProperty. I've heard this might be bad practice, but it's working exceptionally well.
Thanks everyone for your time - I appreciate it.
