• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Valued Contributor
    Sweep with Guide Rail using API ??
    114 Views, 3 Replies
    06-29-2012 10:36 AM
    Hi Guys,
    We are developing an equation driven 3d spline using VBA.
    It generates a 3D spline, guide rail, and tool profile, but we're having trouble figuring out how to do the actual "sweep with guide rail" using the API.
    Attached is an .ipt of the shapes our program is generating automatically.
    The problem is we are having to manually create the sweep after the geometry is created.
    How can we automate the sweep with guide rail process?  Can someone point me in the right direction on how to do something like this?
    Autodesk Inventor 2012 Certified Assosicate
    Autodesk Inventor 2012 Certified Professional
    Please use plain text.
    Valued Contributor
    Re: Sweep with Guide Rail using API ??
    06-29-2012 10:38 AM in reply to: ROBTRONIX
    BTW still using Inventor 2011
    Valued Contributor
    thomaskennedy
    07-03-2012 01:37 AM in reply to: ROBTRONIX
    This should get you going, it will do your first sweep feature :
    Public Sub SweepFeature()
    'reference the part doc
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    'reference to the sketches
    Dim oSketches As PlanarSketches
    Set oSketches = oPartDoc.ComponentDefinition.Sketches
    'get the TOOL 1 sketch
    Dim oSketch As PlanarSketch
    Set oSketch = oSketches.Item("TOOL 1")
    ' Create a profile from oSketch (TOOL 1)
    Dim oProfile As Profile
    Set oProfile = oSketch.Profiles.AddForSolid
    'get the PATH sketch
    Dim oSketch2 As PlanarSketch
    Set oSketch2 = oSketches.Item("PATH")
    'get the first line in the sketch
    Dim oSketchLine1 As SketchLine
    Set oSketchLine1 = oSketch2.SketchLines.Item(1)
    'set oSketchLine1 as the path
    Dim oPath As Path
    Set oPath = oPartDoc.ComponentDefinition.Features.CreatePath(oSketchLine1)
    'get the RAIL 1 sketch (a 3D sketch in this case, not a planar sketch)
    Dim oSketches3D As Sketches3D
    Set oSketches3D = oPartDoc.ComponentDefinition.Sketches3D
    Dim oSketch3D As Sketch3D
    Set oSketch3D = oSketches3D.Item("RAIL 1")
    'get the first spline in the sketch
    Dim oSketchSpline As SketchSpline3D
    Set oSketchSpline = oSketch3D.SketchSplines3D.Item(1)
    'set the spline as the guide path
    Dim oGuide As Path
    Set oGuide = oPartDoc.ComponentDefinition.Features.CreatePath(oSketchSpline)
    'do the sweep feature with Path and Guide Rail
    Dim oSweep As SweepFeature
    Set oSweep = oPartDoc.ComponentDefinition.Features.SweepFeatures.AddUsingPathAndGuideRail(oProfile, oPath, oGuide, PartFeatureOperationEnum.kCutOperation, SweepProfileScalingEnum.kNoProfileScaling)
    End Sub
    If you search in the API help ( ? > Additional Resources > Programming Help ) for 'sweep' you will find some help in there. Theres also some sample code in the help to create a sweep feature.
    Hope this helps
    Tom
    Valued Contributor
    07-19-2012 08:03 AM in reply to: thomaskennedy
    Tom,
    Thanks a bunch, that worked out great!
    Would you know how to go about doing a circular pattern of the swept features?
    Rob
