• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    New Member
    Suppress Solid Bodies, using iLogic
    55 Views, 1 Replies
    01-15-2013 01:54 AM
    Hi all,
    in addition to this question
     http://forums.autodesk.com/t5/Autodesk-Factory-Design-Suite/Suppress-Solid-Body/td-p/3110970
    I would like to have some help with the code for hiding different Solid Bodies:
    with the User Parameter type, I want to select a certain type of Shackle and suppress / hide the other Solid Bodies
    Gerben
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: Suppress Solid Bodies, using iLogic
    01-17-2013 01:35 PM in reply to: TWD_Gerben
    Hi TWD_Gerben,
    There is some example code at this link that might help:
    http://inventortrenches.blogspot.com/2013/01/ilogic-solid-body-visibility.html
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
