Sheet Count
Sheet Count
Sheet Count
Hi All
I have produced a .dwg template, all set up with title blocks and sheet formats etc etc.
The only issue I have is when the template is opened 'Sheet:1' is always at the bottom of the column (See attached) so the sheet count takes this as sheet one. When a draughtsman inserts his own Sheet Format the sheet count immediatley goes to 2/2 whereas is should read 1/1.
Is there anyway of removing this 'Sheet:1'?
Any help appreciated
Gareth
ekinsb
Hi Gareth,
I don't believe it's possible to delete that last sheet.  Inventor requires a drawing to always have at least one sheet.
You could possibly get the result you want using some kind of API solution that would automatically delete the original sheet when a new sheet is added.
Brian Ekins
Mod the Machine blog
jdkriek
Wrote this real quick, but the following iLogic should do the trick. In your template double click on the sheet and rename it to "remove". When you get done it should read "remove:1" instead of "sheet:1". Set the event trigger to OnSave, so when the drawing is saved it will remove the first sheet named this and leave the rest alone. Note there needs to be another sheet present in order to delete the first sheet and we don't want to keep deleting the first sheet all the time so we name it something specific via the template.
Dim oApp As Application: oApp = ThisApplication
Dim oDoc As Inventor.DrawingDocument: oDoc = oApp.ActiveDocument
Dim oSheets As Sheets: oSheets = oDoc.Sheets
Try
	Dim oSheet As Sheet: oSheet = oSheets.Item("remove:1")
	oSheet.Activate
	oSheet.Delete
Catch
'Do nothing, the sheet is gone.
End Try
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Many Thanks for the reply, I will try and implement it later.
Thanks for replying
Gareth
