Autodesk Inventor Customization
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Setting MultiValue List to a paramter
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello
I have the following rule:
If OD=900 mm And Filter_Type = "Aerob" Then
MultiValue.SetList("FilterSize", 0.2, 0.3, 0.4, 0.5, 2.2, 2.3, 2.4, 2.5)
End If
If OD=900 mm And Filter_Type = "Donaldson DLM" Then
MultiValue.SetList("FilterSize", V3/7S, V4/7S, V8/7S)
End IfFor first condition everything is ok. But when the second one is valid it gives error:
Conversion from string "V3/7" to type 'Double' is not valid.
Maybe I should add that the parameter "FilterSize" was made as Text and multi-value.
And of course I not familiar at all with programming...
What would be the solution?
Windows 7 x64
Dell Precision T7400 Intel(R) Xeon(R) CPU X5472 @ 3.00GHz (4 CPU's), 8Gb RAM, NVIDIA Quadro FX 5600 1536MB GDDR3
Re: Setting MultiValue List to a paramter
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I noticed that you are using a variable called '7S'. Could you give me the rest of the code so that I can see how those variables are being initialized? Being that you can't begin an Inventor parameter using a number I assume that it is being declared via a DIM inside of your iLogic. No matter, it may be causing the problem.
I ran a test (switching that to S7) with the below code, and ran into no problems.
'' Here is a test to perform.
'' The parameter type of all the INVENTOR parameters are as follows.
' Filter_Type --- Text - Multivalue w/(2) values : ("Filter1", "Filter2")
' FilterSize --- mm - Multivalue w/(?) values : Is assigned by iLogic below
' OD --- mm - Single Value : currently 900mm
'Notice that 7S has been changed to S7!
Dim V3, V4, V8, S7 As Double
V3 = 300 mm
V4 = 400 mm
V8 = 800 mm
S7 = 7 ul
If OD=900 mm And Filter_Type = "Filter1" Then
End If
If OD=900 mm And Filter_Type = "Filter2" Then
MultiValue.SetList("FilterSize", V3/S7, V4/S7, V8/S7)
End If
If my solution seems to remedy your problem, please press the Accept Solution button, -
as it increases my power levels and will eventually help to elevate me towards outer space.
Check out my iLogic injection tool here : http://goo.gl/ce1Qg
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry, I was not precise with my description and the code. I have found the mistake.
I will simplify my initial code:
MultiValue.SetList("Filter_Size", "V3/7S", "V4/7S")
End If
MultiValue.SetList("Filter_Size", "0.2", "0.3")
End If
If Filter_Size= 0.2 Then
d1= 100 mm
d2= 200 mm
End If
If Filter_Size= 0.3 Then
d1= 100 mm
d2= 300 mm
End If
If Filter_Size= "V3/7S" Then
d1= 150 mm
d2= 200 mm
End If
If Filter_Size= "V4/7S" Then
d1= 250 mm
d2= 100 mm
End IfJust because I didn't use double quote in line 9 and 14 for the value of Filter_Size I had this error.
So it should be like this:
If Filter_Size= "0.2" Then
and
If Filter_Size= "0.3" Then
In my first post I didn't wrote the other code which was using the same "Filter_Size". So it was hard to understand.
Thanks anyway for your try!
Windows 7 x64
