Select Set Problem
Select Set Problem
matt_jlt
Select Set Problem
matt_jlt
I have a select set that contains only faces. What i can't work out is how to access the properties all of the faces in the select set as i need to set the render style of them all.
Any on have any ideas?
Thanks, Matt
There are examples in the help, but here is the
general approach. Place the following code in a module in the part document
project.Select a few faces on a part and run the macro.
Public Sub OverrideFaceStyle()
    Dim ss As
SelectSet
    Set ss =
ThisDocument.SelectSet
    Dim newStyle
As RenderStyle
    Set newStyle =
ThisDocument.RenderStyles.Item("Blue")
    Dim oFace As Face
    For Each oFace In
ss
        Call
oFace.SetRenderStyle(kOverrideRenderStyle, newStyle)
Next
End Sub
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
render style of them all. Any on have any ideas? Thanks,
Matt
matt_jlt
Sorry mate i should have made it a bit clearer, What i am trying to do is to apply the render style to all of the faces at once. The method you suggested is what i currently use but it applies the render style to every face one at a time. Because the files i am using have thousands of faces this takes up a lot of time to do it this way. So if anyone has any ideas it is much appreciated as ive hit a brick wall on this one. Cheers
As far as I know, you'll have to change them
individually. If you are doing this in an add-in you would probably see a
performance increase (and get other benefits) by using a change-processor.
Is this in the context of an assembly or imported
geometry in a faceted format? If an assembly, could you just change the
renderstyle of complete components? If in a part, could you affect the change at
the feature level rather than by face?
Sorry
matt_jlt
Thanks for the help guys, much appreciated.
It is for imported geometry. I ended up turning off screen refresh and added in some code to detect if a face is already part style to not perform the function on it, still not the results i was after but it's a little faster.
