Autodesk Inventor Customization
- Start Article
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Saveas STP -save options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
How can I access the save option while saving stp
Call oDoc.SaveAs("C:\temp\test.stp", True)using this I get the default "include sketches" options
I want to exclude sketches using API
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
Re: Saveas STP -save options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When using the SaveAs method you get the default behavior and don't have control over the various translator settings. In order to control the setting you need to drive the translator directly. There are several samples in the API help that demonstrate this and there's on in particular that shows how to write out a STEP file. The sample doesn't show all of the options that are available. That's also listed in the API help but when I just looked for it now found it's not accessible through the index. Instead you have to search for it. We need to correct this. In the meantime, I copied and pasted the material in a Word document, which I've attached. You'll see the option for excluding sketches there.
Brian Ekins
Inventor API Product Designer
Manufacturing Solutions
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Brian,
oOptions.Value("IncludeSketches") = False
This did the trick
