I've installed the developer tools:
C:\Users\Public\Documents\Autodesk\Inventor 2013\SDK\DeveloperTools\
The Inventor 2013 API help file says that the Wizard sub directory will be empty because the SDK install does the VS2010 template install.
But the
C:\Users\Public\Documents\Autodesk\Inventor 2013\SDK\DeveloperTools\Tools\Wizards
is NOT empty and the SDK install did NOT (as far as I can see) install the VC or VBA or C# Inventor project templates in my VS10.
Should I run the InventorWizards.msi even though the help file tells me I don't need to?
