• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Distinguished Contributor
    Replace styles in Drawing
    197 Views, 5 Replies
    08-24-2012 02:52 AM
    Hi
    I have some styles I will like to replace in some drawings
    but how? I cant find any function to do this.
    Do I missing some thing ?
    Dim oIDWStyles As Inventor.DrawingStylesManager
     Set oIDWStyles = oDrawDoc.StylesManager
     Dim oldstyle As style
     Dim Newstyle As style
       For Each oldstyle In oIDWStyles.Styles
         If oldstyle.Name = "Old style" Then
           '  Debug.Print oldstyle.Name & " : " & oldstyle.InternalName
            For Each Newstyle In oIDWStyles.Styles
              If Newstyle.Name = "New style" Then
                'Debug.Print Newstyle.Name & " : " & Newstyle.InternalName
                End If
            Next
            'How to replace oldstyle with newstyle
             'oldstyle = Newstyle
         End If
       Next
    René J
    Please use plain text.
    Re: Replace styles in Drawing
    08-24-2012 05:31 AM in reply to: Rene-J
    This worked for me:
    ' Create the parts list and set a reference to it.
        Dim oPartsList As PartsList
        Set oPartsList = oSheet.PartsLists.Add(oDrawingView1, oPlacementPoint)
        oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("PARTS LIST PART")
    Hope this helps.
    Chris
    Valued Mentor
    jdkriek
    08-24-2012 05:43 AM in reply to: Rene-J
    You can rename it, delete it, set another style as the object default, but no direct replace that I know of.
    If you set the new styles as object defaults, then you could change all elements to the active standard.
    Jonathan D. Kriek
    Inventor Applications Engineer
    Autodesk Inventor Certified Expert
    Microsoft Certified Application Developer
    _____________________________________________________
    Did I help you? Please choose Accept as Solution or Kudos below
    08-24-2012 05:57 AM in reply to: jdkriek
    UGHHHH....I swear I read "parts list style" the first time I read your post!  Thats what I get for responding before I've had some caffeine!
    Valued Mentor
    jdkriek
    08-24-2012 06:04 AM in reply to: cmines
    Get some coffee, it will be alright - for a Friday :smileywink:
    Jonathan D. Kriek
    09-05-2012 08:59 AM in reply to: jdkriek
    Thanks Jonathan
    Finally I got the time, to look at your suggestion.
    I'm sorry I have not commented earlier, I've been on vacation.
    I thought there was an easier solution.
    René J
