Message 1 of 1
Remote Server Errors
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Has anyone suffered from run-time error 462 'the remote server machine does not exist or is unavailable' when using Access vba?
I am using access vba to open many assembly files to update them and then save them. The code gets a list of assemblies from a database and iterates through each one opening them up, updating and finally saving then closing the document.
After an indeterminate number of assemblies, Inventor suddenly shuts down and gives me the error above.
I have included the code I am using below:
Dim rs As ADODB.Recordset
Dim cn As ADODB.Connection
Dim cm As ADODB.Command
Dim InvAppDoc As Inventor.AssemblyDocument
Dim i As Long
i = 0
If (InvApp Is Nothing) Then
Set InvApp = StartInventor()
End If
Set cn = New ADODB.Connection
Set cn = CurrentProject.Connection
Set rs = New ADODB.Recordset
rs.CursorLocation = adUseClient
Set cm = New ADODB.Command
cm.ActiveConnection = cn
cm.Parameters.Append cm.CreateParameter("@FileLinksChecked", adBoolean, adParamInput, 1, 0)
cm.Parameters.Append cm.CreateParameter("@FileExtension", adWChar, adParamInput, Len("iam"), "iam")
If (lngCount <> 0) Then
cm.CommandText = "SELECT TOP " & lngCount & " FullPath FROM InventorFiles WHERE (FileLinksChecked=@FileLinksChecked AND FileExtension=@FileExtension);"
Else
cm.CommandText = "SELECT FullPath FROM InventorFiles WHERE (FileLinksChecked=@FileLinksChecked AND FileExtension=@FileExtension);"
End If
Set rs = cm.Execute
Do Until (rs.EOF Or bCancel)
If (GetAttr(rs.Fields("FullPath").Value) And vbReadOnly) Then
Call SetAttr(rs.Fields("FullPath").Value, 0)
End If
Set InvAppDoc = InvApp.Documents.Open(rs.Fields("FullPath").Value)
Call InvAppDoc.Update2(True)
Call InvAppDoc.Save2(True)
Call InvApp.ActiveDocument.Close(False)
Call UpdateInventorFileAsChecked(rs.Fields("FullPath").Value)
rs.MoveNext
loop
InvApp.Quit
Set InvApp = Nothing
Set InvAppDoc = Nothing
Does anyone know why this is being caused?
