• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Member
    s_kul
    Read workpoints and parts used to add dimension
    126 Views, 2 Replies
    07-28-2011 04:37 AM
    I want to read the workpoints and parts used to add dimension in the drawing. Using VBA I can get workpoints using <Dimension>.IntentOne.Geometry.AttachedEntity. However I have not seen any way to read it in VB.NET.
    Can anybody please suggest me the way to read it?
    Please use plain text.
    ADN Support Specialist
    xiaodong.liang
    Re: Read workpoints and parts used to add dimension
    07-28-2011 08:52 PM in reply to: s_kul
    the similar code should be also work in VB.NET. did you get any error or failure? I used the following code, it works well to me. It is a code within a standalone application. It asks user to select a dimension and pop out the information of the attaced entity if it is a workpoint.
       Private Sub test()
            Dim m_inventorApp As Inventor.Application = Nothing
            Try
                m_inventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
            Catch ex As Exception
            End Try
            ' Get a feature selection from the user
            Dim oObject As Object
            oObject = m_inventorApp.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Pick a dimension")
            If TypeOf oObject Is LinearGeneralDimension Then
                Dim oDrawDim As LinearGeneralDimension = oObject
                Dim oAttEntity As Object = oDrawDim.IntentOne.Geometry.AttachedEntity
                If TypeOf oAttEntity Is WorkPoint Then
                    Dim oWP As WorkPoint = oAttEntity
                    MsgBox("pt x,y,z" & oWP.Point.X & "; " & oWP.Point.Y & "; " & oWP.Point.Z)
                End If
            End If
        End Sub
    Best regards,
    Xiaodong Liang
    Developer Consultant
    Autodesk Developer Technical Services
    Xiaodong Liang
    Autodesk Developer Network
    Member
    s_kul
    07-30-2011 01:51 AM in reply to: xiaodong.liang
    Thank you.
    This solution works for me.
