• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Active Member
    bijibijmak
    Accepted Solution
    Problem with Project Falcon ad-in in Inventor 2013
    117 Views, 2 Replies
    12-12-2012 09:11 PM
    Just downloaded and Installed Project Falcon on my Inventor 2013 (64 bit) educational. Although I enable the ad-in in Inventor and using ad in manager from start menu, I am unable to use it to run simulations.
    What can I do?
    Please use plain text.
    Valued Contributor
    Re: Problem with Project Falcon ad-in in Inventor 2013
    12-13-2012 03:41 AM in reply to: bijibijmak
    I get a similar thing, if I have no geomtery in my model I can enter the Falcon environment, however, if any geometry exists Falcon will crash inventor.
    *Expert Elite*
    Curtis_Waguespack
    12-13-2012 07:59 AM in reply to: MattH_Work
    Hi bijibijmak,
    You might get a better response here:
    Autodesk Discussion Groups > Autodesk Labs  > Project Falcon
    http://forums.autodesk.com/t5/Project-Falcon/bd-p/Falcon
    Maybe the moderators can move this topic to that forum to help others in the future.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
