Printmanager Papersize
Message 1 of 22
Anybody have any idea why the paper size won't set to A1. See attached clip
and picture of the printer default setting.
KWiKMcad
Kent Keller
Replies (21)
Message 2 of 22
Sorry, I meant to zip that rather than 7z
KWiKMcad
Kent Keller
"Kent" wrote in message
news:6219550@discussion.autodesk.com...
KWiKMcad
Kent Keller
Message 3 of 22
Anybody? It seems to only be certain printers that won't set to A0 or A1
even though those sizes are listed in their drivers. I believe some
printers through an error when being set but PDFCreator just acts like
everything worked fine even though it didn't.
KWiKMcad
Kent Keller
KWiKMcad
Kent Keller
Message 4 of 22
Brian or Sanjay, any feedback on what might be causing certain printers to
not accept certain papersizes as is shown in the AVI?
KWiKMcad
Kent Keller
KWiKMcad
Kent Keller
Message 5 of 22
I thought I had responded to this but I must not have. I was able to
reproduce the problem on my side and filed a change request so it can be
investigated further. It looks like some of the sizes always fail, even
when the printer will support them.
Brian Ekins
Autodesk Inventor API Product Designer
http://blogs.autodesk.com/modthemachine
Message 6 of 22
Thanks Brian,
Glad to know it isn't just me missing something obvious
KWiKMcad
Kent Keller
"Brian Ekins (Autodesk)" wrote in message
news:6227641@discussion.autodesk.com...
Brian Ekins
Message 7 of 22
I don't see where this is listed in the SP1 readme. Did it not get
addressed?
KWiKMcad
Kent Keller
Brian Ekins
Message 8 of 22
Kent,
Sorry, this issue has not been addressed yet. Please use the following ID to
track this issue: 1241388.
Sanjay-
Message 9 of 22
Does anyone know if this has been fixed in 2011?  I seem to have the same problem and I don't know how to track the issue with the ID.  Thx.
Message 10 of 22
YuhanZhang
The issue should have been fixed in 2011, but if you see similar issue would you please let us know your printer dirve, and add a snippet of code to reproduce the problem, we can look into it.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 11 of 22
Yes, I am still seeing the issue.  I am printing to a "KONICA MINOLTA C650 Series PCL".  We are using the appropriate driver for a 64-bit machine.  I've attached a snippet of code.  Every print is coming out 8-1/2 x 11 (the default paper size).
Thanks!
Message 12 of 22
skyngu
i know it is old post. is it fixed yet?
Autodesk Inventor Professional 2019
Message 13 of 22
YuhanZhang
The defect logged for this issue is fixed in Inventor 2011.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 14 of 22
skyngu
i still got same issue in invetor 2013. so it should be matter of printer's model (sharp m620n)
Message 15 of 22
YuhanZhang
Which paper size you want to print? And can you check if this printer driver supports the paper size you choose from API. I have a similar driver "Sharp  MX-M620N PCL6" which supports the A3 and smaller sizes.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 16 of 22
skyngu
letter and ledger size. it picks ledger size paper in the routie. after it submits to printermanager, it changes to letter size.
when I print document by using hp printer(hp 8150) or pdf tool(pdf creator), it works well. it comes out ledger size as expected.
how to check if this printer driver supports the paper size?
thanks for reply.
Message 17 of 22
skyngu
Sub RD_Printer()
Dim oDrgDoc As DrawingDocument
Set oDrgDoc = ThisApplication.ActiveDocument
Dim oDrgPrintMgr As DrawingPrintManager
Set oDrgPrintMgr = oDrgDoc.PrintManager
Dim oSheet As Sheet
Set oSheet = oDrgDoc.ActiveSheet
oDrgPrintMgr.Printer = "M620N_ENG"
Select Case oSheet.Size
Case kADrawingSheetSize
oDrgPrintMgr.PaperSize = kPaperSizeLetter
Case kBDrawingSheetSize
oDrgPrintMgr.PaperSize = kPaperSizeLedger
End Select
If oSheet.Orientation = kLandscapePageOrientation Then
oDrgPrintMgr.Orientation = kLandscapeOrientation
Else
oDrgPrintMgr.Orientation = kPortraitOrientation
oDrgPrintMgr.ScaleMode = kPrintFullScale
oDrgPrintMgr.AllColorsAsBlack = False
oDrgPrintMgr.PrintRange = kPrintCurrentSheet
oDrgPrintMgr.SubmitPrint
End Sub
Message 18 of 22
YuhanZhang
To check the paper sizes the printer supports you can find it with below steps:
1. Right click the printer in your Devices and Printers.
2. Choose Printing preferences.
3. Click the Advanced... button.
4. Click the Paper/Output->Paper Size dropdown, you can see the paper size list the printer supports.
For the issue your printer always prints the Letter size even you choose the Ledger size, can you double check with the Inventor UI print function? If you can reproduce this with Inventor UI function that would be a UI issue.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 19 of 22
skyngu
my bad that i didnt state issue clearly. i can print ledger size paper manually select from printing perferences, however, not through API.
i check printer setting. it shows up letter and ledger size paper.
thanks.
Message 20 of 22
YuhanZhang
Sorry for late response. Can you let me how you added the M620N_ENG printer? I can test it here but now sure how to install this printer dirver.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
