• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor Customization
    Valued Contributor
    Position of Part in idw
    71 Views, 2 Replies
    01-21-2013 05:50 PM
    How to get postion of faces of part when place on idw drawing file???
    Do we need to use (ThisApplication.MeasureTools.GetMinimumDistance(oTG.CreatePoint2d(0, 0), oFa.PointOnFace)????
    If we use that we will get distance  but how to get face postion on idw. do we need to use edges?? or lines???
    Mechanical Engineer
    Inventor Applications Engineer
    If my solution seems to remedy your problem, please press the Accept Solution button, Some KUDOS -
    Please use plain text.
    Valued Contributor
    Re: Position of Part in idw
    01-24-2013 03:58 PM in reply to: ADNpati
    I found way again by myself.....
    Using ModelToSheetSpace with drawingview we can get reference to anything from Model i.e., 3D Enviroment to sheet space Enviroment.
    working on code and will post you in 10 mins... cheers
    Mechanical Engineer
    Valued Contributor
    01-24-2013 04:38 PM in reply to: ADNpati
    Here is the complete code, hope this will be helpful for somebody :smileyhappy: :smileyhappy: :smileyhappy:
    Option Explicit
    Sub FaceRecognitiononIDW()
        Dim oDrawingDoc As DrawingDocument
        Set oDrawingDoc = ThisApplication.ActiveDocument
        Dim oDef As ComponentDefinition
        Dim itemCnt As Integer
        itemCnt = 0
        Dim oView As DrawingView
        Set oView = oDrawingDoc.ActiveSheet.DrawingViews(1)
        Dim oDoc As Document
        Set oDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
        Dim oPartDoc  As Document
        Dim oRrubberPart As PartDocument
        Dim oAllRef As DocumentsEnumerator
        Dim occ As ComponentOccurrence
        Dim occDef As ComponentDefinition
        Dim oTextBox As TextBox
        Dim oPartCompDef As PartComponentDefinition
        Dim oSurfBody As SurfaceBody
        Dim oFa As face
        ' Set a reference to the active sheet.
        Dim oActiveSheet As Sheet
        Set oActiveSheet = oDrawingDoc.ActiveSheet
        For Each occ In oDoc.ComponentDefinition.occurrences
        If occ.DefinitionDocumentType = kPartDocumentObject Then
            If occ.SurfaceBodies.count <> 0 Then
                Set oPartDoc = occ.Definition.Document
                Set occDef = oPartDoc.ComponentDefinition
                Set oSurfBody = occDef.SurfaceBodies(1)
                Set oPartCompDef = occ.Definition
                For Each oFa In oSurfBody.Faces
                    itemCnt = itemCnt + 1
                    If oFa.SurfaceType = kPlaneSurface Then
                    ' Getting a planar surface face above
                    ' ground level and face not connected
                    ' to any other face
                        If oFa.TangentiallyConnectedFaces.count = 0 Then
                            If oFa.PointOnFace.Z <> "0" Then
                                If ThisApplication.MeasureTools.GetAngle(oFa, occ.Definition.WorkPlanes(3)) = "0" Then
                                    Dim oFaProxy As FaceProxy
                                    Call occ.CreateGeometryProxy(oFa, oFaProxy)
                                    ' Get the point of the sketch
                                    Dim oMidPoint As Point2d
                                    Set oMidPoint = oView.ModelToSheetSpace(oFaProxy.PointOnFace)
                                    ' Set a reference to the TransientGeometry object.
                                    Dim oTG As TransientGeometry
                                    Set oTG = ThisApplication.TransientGeometry
                                    Dim oLeaderPoints As ObjectCollection
                                    Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
                                    ' Create a few leader points.
                                    Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.x, oMidPoint.y))
                                    Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.x + 0.5, oMidPoint.y + 0.5))
                                    ' Create text with simple string as input. Since this doesn't use
                                    ' any text overrides, it will default to the active text style.
                                    Dim sText As String
                                    sText = "API Leader Note"
                                    Dim oLeaderNote As LeaderNote
                                    Set oLeaderNote = oActiveSheet.DrawingNotes.LeaderNotes.Add(oLeaderPoints, sText)
                                    ' Insert a node.
                                    Dim oFirstNode As LeaderNode
                                    Set oFirstNode = oLeaderNote.Leader.RootNode.ChildNodes.Item(1)
                                End If
                            End If
                        End If
                    End If
                Next
            End If
        End If
        Next
    End Sub
     If found useful give some kudos  :smileyhappy:  :smileyhappy:  :smileyhappy:
    Mechanical Engineer
