My attempt to plot all related files form an ".iam" resulted with the following code. If anyone interested in cleaning/updating/modifying please post back here. The code as is working for us. We use an eight digit number for file name. Plotted PDF will have revision added to file name. I am a self taught programmer and I am sure someone from this forum will be able to simplify the code and post back here for others.
Any chance of making an addin or iLogic code for similar functionality?
Private PDFPATH As String 'FOLLOWING CODE USES CODE FROM http://www.mcadforums.com/forums/viewtopic.php?f=15&t=10687 'AND OTHER PLACES INCLUDING INVENTOR HELP. Public Sub PrintRefFiles() 'BOMQuery() ' Set a reference to the assembly document. ' This assumes an assembly document is active. Dim oDoc As AssemblyDocument Set oDoc = ThisApplication.ActiveDocument Dim ASSYIDW As String ASSYIDW = oDoc.FullFileName ASSYIDW = Replace(ASSYIDW, Right(ASSYIDW, 4), ".idw") If Dir(ASSYIDW) <> "" Then 'Debug.Print strDisplay Dim oDrawDoc As drawingDocument Set oDrawDoc = ThisApplication.Documents.Open(ASSYIDW) oDrawDoc.Activate Debug.Print ThisApplication.ActiveDocument SaveAsPDFto oDrawDoc.Close True End If 'GET 8 DIGIT FILE NAME WITH .IDW. ASSUMES C:\TEMP EXISTS. ELSE CREATE MANUALLY. PDFPATH = "C:\TEMP\" & Right(oDoc.FullFileName, 12) PDFPATH = Left(PDFPATH, Len(PDFPATH) - 4) 'REMOVES .IDW CreateFolder 'CHECKS AND CREATES FOLDER IF NOT EXIST Dim FirstLevelOnly As Boolean If MsgBox("First level only?", vbYesNo) = vbYes Then FirstLevelOnly = True Else FirstLevelOnly = False End If ' Set a reference to the BOM Dim oBOM As BOM Set oBOM = oDoc.componentDefinition.BOM ' Set whether first level only or all levels. If FirstLevelOnly Then oBOM.StructuredViewFirstLevelOnly = True Else oBOM.StructuredViewFirstLevelOnly = False End If ' Make sure that the structured view is enabled. oBOM.StructuredViewEnabled = True 'Set a reference to the "Structured" BOMView Dim oBOMView As BOMView Set oBOMView = oBOM.BOMViews.Item("Structured") 'Initialize the tab for ItemNumber Dim ItemTab As Long ItemTab = -3 Call QueryBOMRowProperties(oBOMView.BOMRows, ItemTab) End Sub Private Sub QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator, ItemTab As Long) ItemTab = ItemTab + 3 ' Iterate through the contents of the BOM Rows. Dim i As Long For i = 1 To oBOMRows.Count ' Get the current row. Dim oRow As BOMRow Set oRow = oBOMRows.Item(i) 'Set a reference to the primary ComponentDefinition of the row Dim oCompDef As componentDefinition Set oCompDef = oRow.ComponentDefinitions.Item(1) Dim strDisplay As String strDisplay = oRow.ReferencedFileDescriptor.FullFileName 'Debug.Print strDisplay strDisplay = Replace(strDisplay, "\\FTE-DRAFT\drawings$", "H:") strDisplay = Left(strDisplay, Len(strDisplay) - 4) & ".idw" If Dir(strDisplay) <> "" Then 'Debug.Print strDisplay Dim oDrawDoc As drawingDocument Set oDrawDoc = ThisApplication.Documents.Open(strDisplay) oDrawDoc.Activate Debug.Print ThisApplication.ActiveDocument SaveAsPDFto oDrawDoc.Close True End If Dim oPartNumProperty As Property Dim oDescripProperty As Property If TypeOf oCompDef Is VirtualComponentDefinition Then Else If Not oRow.ChildRows Is Nothing Then Call QueryBOMRowProperties(oRow.ChildRows, ItemTab) End If End If Next ItemTab = ItemTab - 3 End Sub Private Sub SaveAsPDFto() ' Get the PDF translator Add-In. Dim oPDFTrans As TranslatorAddIn Set oPDFTrans = ThisApplication.ApplicationAddIns.ItemById( _ "{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") If oPDFTrans Is Nothing Then MsgBox "Could not access PDF translator." Exit Sub End If Dim oDoc As Document Dim oFileName As String Dim sPath As String Set oDoc = ThisApplication.ActiveDocument oFileName = oDoc.FullFileName Dim oPtDoc As Document Set oPtDoc = oDoc.ActiveSheet.DrawingViews(1).ReferencedFile.ReferencedDocument 'Debug.Print oPtDoc.FullFileName 'GET THE REVISION NUMBER FROM REFERENCED FILE (NOT IDW REVISION - AS OUR STD) Dim oPtSumInfo As PropertySet Set oPtSumInfo = oPtDoc.PropertySets.Item("Inventor Summary Information") Dim oPtRev As Property Set oPtRev = oPtSumInfo.Item("Revision Number") sPath = Right(oFileName, 12) sPath = Replace(sPath, Right(oFileName, 4), oPtRev.Value & ".pdf") '(oFileName, Right(oFileName, 4), oPtRev.Value & ".pdf") sPath = PDFPATH & "\" & sPath '& Right(sPath, 12) 'Debug.Print spath ' Create some objects that are used to pass information to the translator Add-In. Dim oContext As TranslationContext Set oContext = ThisApplication.TransientObjects.CreateTranslationContext Dim oOptions As NameValueMap Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap If oPDFTrans.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, _ oContext, oOptions) Then ' Set to print all sheets. This can also have the value ' kPrintCurrentSheet or kPrintSheetRange. If kPrintSheetRange ' is used then you must also use the CustomBeginSheet and ' Custom_End_Sheet to define the sheet range. oOptions.Value("Sheet_Range") = kPrintAllSheets ' Other possible options... 'oOptions.Value("Custom_Begin_Sheet") = 1 'oOptions.Value("Custom_End_Sheet") = 5 'oOptions.Value("All_Color_AS_Black") = True 'oOptions.Value("Remove_Line_Weights") = True 'oOptions.Value("Vector_Resolution") = 200 ' Define various settings and input to provide the translator. oContext.Type = kFileBrowseIOMechanism Dim oData As DataMedium Set oData = ThisApplication.TransientObjects.CreateDataMedium oData.filename = sPath '"C:\temp\test.pdf" 'MSG = MsgBox("Will add Rev automaticaly (if any)." & vbCrLf & vbCrLf & "PRINTING AS PDF TO:" & vbCrLf & vbCrLf & sPath, vbOKCancel) 'If MSG = vbOK Then ' Call the translator. Call oPDFTrans.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData) 'Dim r As Long 'r = ShellExecute(0, "open", oData.filename, 0, 0, 1) 'If r < 32 Then MsgBox ("Couldn't start your PDF-reader") 'End If 'MSG = VBOK End If End Sub Sub CreateFolder() Dim fso Dim fol As String fol = PDFPATH ' "c:\MyFolder" ' change to match the folder path Set fso = CreateObject("Scripting.FileSystemObject") If Not fso.FolderExists(fol) Then fso.CreateFolder (fol) Else 'MsgBox fol & " already exists!", vbExclamation, "Folder Exists" End If End Sub
After 29 views, no one wants comment?
Come on friends, give me some feedback on the code.
Anyone got a better solution?
Any chance of converting this to an add-in?
Thank you.
Here is the code that I use.http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Printing-all-drawings-of-an-assembly-f...
It is the code that was posted by Brendan Henderson. Looks like it works similar to yours. I like this one cause it used the system printer. I use a program called PDF Creator and have it setup to save the pdf as the filename. Works pretty slick and is pretty fast.
