Place Components with Imates by VBA
Our end product is a combination of several assemblies which are placed on (composit)Imates.
It is no problem to realize this manually.
Our vba-programmer tries to place the assemblies by a program, but he doesn't know how to activate the checkbox "use Imate" (place component).
The command "replace componet" is no problem to program, so we work with dummies which has to be replaced.
This is a workable solution, but what we want to do is to place an assembly in stead of replace the assembly.
Is there a possibility to activate the checkbox "use Imate" by a vba program ?
HEEEEELP !!!!!!!!!!!!!!11
You should be posting in the Inventor Customization NG. Might have better luck there
anyhow.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"boonedam" wrote in message news:f0ca598.0@WebX.maYIadrTaRb...
The API does not support this as yet.
However a crude method to apply imates when
placing the components through API. Before you insert the
components
atleast once invoke placecomponent command and
check "Use iMate" and cancel the dialog. One of the components
should
be placed through CommandManager as shown (VBA
macro) below.
Sub test()
    Dim pos
As Matrix
    Set pos =
ThisApplication.TransientGeometry.CreateMatrix()
pos.SetToIdentity
    Dim occ1 As
ComponentOccurrence
    Set occ1 =
ThisDocument.ComponentDefinition.Occurrences.Add("c:\part1.ipt",
pos)
    sFname =
"c:\part2.ipt"
     ' Push the filename onto the Inventor
clipboard
    Call
ThisApplication.CommandManager.PostPrivateEvent(kFileNameEvent,
_
sFname)
            Call
ThisApplication.CommandManager.StartCommand(kPlaceComponentCommand)
End
Sub
Cheers,
-Thilak
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Our
(composit)Imates.
Our
The command
to be replaced.
This should be a part of the API soon!!! This seems
to be what a lot of inventor dealers are tooting their horns about, yet you
can't do anything really cool with it until you open it up in the
API
doh!
mike
yet.
components
should
macro) below.
Sub test()
    Dim
pos As Matrix
    Set pos =
pos.SetToIdentity
    Dim occ1 As
ComponentOccurrence
    Set occ1 =
pos)
    sFname =
"c:\part2.ipt"
Inventor clipboard
    Call
_
sFname)
            Call
End
Sub
Cheers,
-Thilak
Our
(composit)Imates.
Our
The
Is there
Thanks for the suggestion. Does somebody know if placing assemblies with Imaties will be possible in the near future ?
