• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    MegaJerk
    Non-Defined (Dynamic) Arrays in iLogic
    182 Views, 1 Replies
    05-23-2012 05:22 AM
    Is there a way to declare a non-bound array (dynamic array?) in iLogic?
    There are examples of set bounds array:
    MyDoubleValues = New Double(){1.2,2.2,3.3}
    But doing something like:
    Dim MyDoubleValues() As Double  ---Or---  MyDoubleValues = New Double()
    Results in an error. On the other hand, the following totally works:
    Dim MyDoubleValues(1) As Double
    Which creates an array with a Ubound of 2
    If my solution seems to remedy your problem, please press the Accept Solution button, -
    as it increases my power levels and will eventually help to elevate me towards outer space.
    Check out my iLogic injection tool here : http://goo.gl/ce1Qg
    Please use plain text.
    MegaJerk
    Re: Non-Defined (Dynamic) Arrays in iLogic
    05-24-2012 09:49 AM in reply to: MegaJerk
    Alright, I sort of solved my own problem. The code below is a test showing that you can make a single slot defined array, make it grow based on user inputs, sort it, and make it shrink to remove any duplicate entries. It's not pretty, but I never claimed that I was a coding genius :smileywink:
    What it does: Produces an input box asking for numerical inputs. When you are done hit cancel or simply hit enter (leaving the input blank), and you will be asked to confirm. Once you confirm, the array will be sorted from lowest to highest and returned to you via a message box.
    The intention of this test was to figure out a way to capture a series of user inputs in a dynamic (on the fly sort of) way, to allow for the later combination of the user array and any predefined array (or series of numbers) that existed in my Inventor assembly as calculated parameters.
    Oh one last note : This is sorting using the Bubble Sort method.
    Dim holder As Object
    Dim fakeArray(0) As String
    Dim i As Integer
    Dim holderList As String
    i = 0
    holder = InputBox("Please Enter Your Channel Possitions", "Number Muncher", "")
    If IsNumeric(holder) = True Then
    fakeArray(i) = holder
    While holder <> ""
    holderList = Join(fakeArray,",")
    holder = InputBox("Please Enter Your Next Value" & vbCrLf &" The Current Values are : " & holderList, "Number Muncher", "") '
    i = i+1
    ReDim Preserve fakeArray(i)
    Else
    ButtonValueTest=MsgBox("Would You Like To Stop Entering Values?", vbYesNo,"Question Time!")
    If ButtonValueTest = vbYes Then
    'MessageBox.Show("You pressed : Yes","Results")
    Exit While
    Else
    'MessageBox.Show("You pressed : No","Results")
    holder = "1"
    End If
    End If
    End While
    End If
    'MessageBox.Show(UBound(fakeArray),"")
    Dim ArraySize As Integer
    ArraySize = UBound(fakeArray)
    Dim slot1, slot2, swapped As Double
    Dim APos As Integer
    Dim IdentCount As Integer
    swapped = 2
    If ArraySize < 1Then
    MessageBox.Show("Array has been sorted: " & holderList, "")
    Else If ArraySize > 0 And ArraySize < 2 Then
    slot1 = fakeArray(0)
    slot2 = fakeArray(1)
    If slot1 < slot2 Then
    MessageBox.Show("Array has been sorted: " & holderList,"")
    Else If slot1 > slot2 Then
    fakeArray(0) = slot2
    fakeArray(1) = slot1
    Else If slot1 = slot2 Then
    'Remove(fakeArray(1))
    ReDim Preserve fakeArray(0)
    MessageBox.Show("An Array has been changed to: " & holderList,"")
    End If
    Else If ArraySize > 1 Then
    'MessageBox.Show("Array Larger Than 1", "")
    While swapped > 1
    swapped = 1
    For APos = 1 To UBound(fakeArray) Step 1
    'MessageBox.Show("Looping through Array","")
    slot1 = fakeArray(Apos-1)
    slot2 = fakeArray(Apos)
    If slot2 < slot1 Then
    fakeArray(Apos-1) = slot2
    fakeArray(Apos) = slot1
    swapped = 2
    Else If slot2 = slot1 Then
    For IdentCount = APos To UBound(fakeArray) Step 1
    'MessageBox.Show("Upper Bound: " & UBound(fakeArray) & " And Ident " & IdentCount, "")
    If IdentCount = UBound(fakeArray) Then
    ReDim Preserve fakeArray(IdentCount - 1)
    Apos = 1
    'MessageBox.Show("New UBound: " & UBound(fakeArray),"")
    Exit For
    End If
    fakeArray(IdentCount) = fakeArray(IdentCount + 1)
    Next
    swapped = 2
    End If
    'MessageBox.Show("APos : " & APos,"")
    If APos >= UBound(fakeArray)
    Exit For
    End If
    Next
    If swapped <> 2 Then
    swapped = 0
    End If
    End While
    MessageBox.Show("Array has been sorted down to: " & holderList,"")
    End If
