Loading excel data into a form
Hello everyone
I'm currently working with a model in which I need to easily change the parameters for. What I've done so far is make a form through iLogic and used that to alter my parameters. That has worked just fine, but now I would like the ability to import certain "sets" from an excel spreadsheet, which has pre-defined parameters, into my form. I was thinking of having a drop-down menu where you can choose a set based on the set name and the pre-defined set parameters would then load into the form and by clicking Apply it would apply them to the model. I've attached a picture of a simple model where you can see my form and model. Where it says Group 1 is where I was thinking of having the different set names, and they would then be loaded into the Height and Wall Thickness input boxes when you've chosen which set you want to use. In Excel I've made a spreadsheet with each set looking like this:
Design 1
Height               1000
Wall thickness   10
Design 2
Height                1200
Wall thickness   12
etc.
The picture of my model:
My question is then, how can I accomplish this? I'm not that good at VBA, so I wouldn't know how to write a code that could do this for me.
Any help appreciated
Tom
MjDeck
Tom,
 Here is a sample part and Excel file that does something like what you want.  In the form, you select a value for the Design parameter.  That will trigger a rule to look up values for the Height and WallThickness parameters.  These are marked as ReadOnly on the form, so that their values are set only by changes to the Design parameter.  One drawback to this method is that you can't use an Apply button.  Changes to the Design parameter have to be propagated immediately to the part in order to run the rule and get the correct values for Height and WallThickness.  Here's a screenshot:
Mike Deck
Software Developer
Hello Mike
This is exactly what I was looking for. Thank you very much!
Tom
