• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Distinguished Contributor
    Lance_White
    Accepted Solution
    Launch External iLogic rule with VBA
    1461 Views, 32 Replies
    09-26-2011 10:52 AM
    Is there someway to launch an external iLogic rule with VBA?. I'd like to add a button to run the iLogic rule.
    Lance W.
    Inventor Pro 2013 (PDS Ultimate)
    Vault Pro 2013
    Windows 7 64
    Xeon 2.4 Ghz 12GB
    Please use plain text.
    Valued Mentor
    Re: Launch External iLogic rule with VBA
    09-26-2011 02:31 PM in reply to: Lance_White
    This has been answered before, but perhaps not exactly this way...
    --- In a VBA module ---
    Public Sub LaunchMyRule1   <--- This is what you would tie to a button in a toolbar.
      RuniLogic "MyRule1"
    End sub
    Public Sub LaunchMyRule2   <--- This is what you would tie to a button in a toolbar.
      RuniLogic "MyRule2"
    End sub
    Public Sub RuniLogic(ByVal RuleName As String)
      Dim iLogicAuto As Object
      Dim oDoc As Document
      Set oDoc = ThisApplication.ActiveDocument
      If oDoc Is Nothing Then
        MsgBox "Missing Inventor Document"
        Exit Sub
      End If
      Set iLogicAuto = GetiLogicAddin(ThisApplication)
      If (iLogicAuto Is Nothing) Then Exit Sub
      iLogicAuto.RunExternalRule oDoc, RuleName
    End Sub
    Function GetiLogicAddin(oApplication As Inventor.Application) As Object
      Dim addIns As ApplicationAddIns
      Set addIns = oApplication.ApplicationAddIns
      Dim addIn As ApplicationAddIn
      Dim customAddIn As ApplicationAddIn
      For Each addIn In addIns
        If (addIn.ClassIdString = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}") Then
          Set customAddIn = addIn
        Exit For
        End If
      Next
    Lance_White
    09-27-2011 10:50 AM in reply to: Gruff
    Thanks.
    Lance W.
    Vault Pro 2013
    Windows 7 64
    Xeon 2.4 Ghz 12GB
    Lance_White
    10-03-2011 09:19 AM in reply to: Gruff
    I can't get this to work and I can't figure out what's wrong. I have looked around and the only other code I can find doesn't work either.
    Nevermind figured it out.
      RuniLogic "MyRule1"
    End sub
      RuniLogic "MyRule2"
    End sub
        Exit Sub
      End If
    End Sub
    'Find the add-in you are looking for
    On Error GoTo NotFound
    Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
    If (addIn Is Nothing) Then Exit Function
    addIn.Activate
    Set GetiLogicAddin = addIn.Automation
    Exit Function
    NotFound:
    End Function
    Lance W.
    Vault Pro 2013
    Windows 7 64
    Xeon 2.4 Ghz 12GB
    12-16-2011 04:59 AM in reply to: Lance_White
    Thanks a lot !
    It works for Inventor 2012 too.
    I just had to modify first line and add () :
    Public Sub LaunchMyRule1 ()
      RuniLogic "MyRule1"
    End sub
    01-26-2012 11:48 AM in reply to: Lance_White
    Mike,
    I've tried using this in a VB6 program. I open up the part first that has the Rule I want to run, but I get an error saying it cannot find the external rule.
    The error occurs at iLogicAuto.RunExternalRule oDoc, RuleName.
    The RuleName is correct and the part does have a rule with the supplied name. Any suggestions?
    Mike Eck
    Senior Designer/ CAD Programmer
    Howden North America
    Using Inventor 2013
    Re : Launch External iLogic rule with VBA
    01-27-2012 05:09 AM in reply to: Lance_White
    This VBA Code is made to launch an external rule only.
    You have to link, in Inventor, an external iLogic rune, and not in the file.
    01-31-2012 03:16 AM in reply to: idubail
    Thanks for the reply, but how do I do that?
    Mike Eck
    Using Inventor 2013
    01-31-2012 12:57 PM in reply to: meck
    Never mind. I just had to change
    to
     iLogicAuto.RunRule oDoc, RuleName
    Mike Eck
    Using Inventor 2013
    Active Contributor
    varga_zsolt
    05-15-2012 08:14 AM in reply to: Lance_White
    I have Inventor pro 2012 but this code doesn't work! I need it can someone help me??????
