Issue with TreeView
Issue with TreeView
amitnkukanur
Issue with TreeView
amitnkukanur
Dear All,
I am trying to create a Treeview of Model tree which displays parts assembly...etc My code is working well and i am able to get the tree view, but the problem is how can i count the quantity of parts/assemblies and display as consolidated. For instance this below snapshot shows my treeview
This above snapshot shows my output
Here besides all parts/assemblies i get Semi-Colons and Numbers rather than consolidated view
For this part in fig
153049 QSL.1_8.8:1
153049 QSL.1_8.8:3
153049 QSL.1_8.8:3
how can i get
153049 QSL.1_8.8 and Quantity as 3 seperately.
Best Regards
Amit
Senior Software Engineer
amitnkukanur
This below is my code as shown below
Public Sub AssmTravel(ByVal InCollection As ComponentOccurrences, ByVal objparentNode As System.Windows.Forms.TreeNode)
Dim setval As Boolean = False
Dim objoccsEnumerator As IEnumerator = InCollection.GetEnumerator()
Dim objcomOccurrence As Inventor.ComponentOccurrence
While (objoccsEnumerator.MoveNext() = True)
objcomOccurrence = objoccsEnumerator.Current
Dim imagetype As Integer
If objcomOccurrence.DefinitionDocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
imagetype = 0
Else
imagetype = 1
End If
Dim objcurrentNode As TreeNode = New TreeNode(objcomOccurrence.Name, imagetype, imagetype)
If (setval = True) Then
Else
objparentNode.Nodes.Add(objcurrentNode)
End If
setval = False
RowCountA += 1
AssmTravel(objcomOccurrence.SubOccurrences, objcurrentNode)
objcurrentNode.Collapse()
End While
'//amit code end
End Sub
philippe.leefsma
That's a pure algorithmic query, we don't deal with this kind of questions specifically on that forum. We rather focus on Autodesk APIs related queries. You will have more luck seeking advice on a general purpose programming forum.
If you are using .Net, this should be easily addressed by using some specific built-in data structures, like Dictionnary or HashTable.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
amitnkukanur
Ok, Thanks for Info. I will work on it.
rgds
amit
