Isolated strange behavior when using DriveConstraintSettings from .net
03:46 AM
- Mute
- Permalink
- Report
I have managed to isolate unexpected, to me, bahavior for DriveConstraintSettings.
If I use drive the constraint detecting contact everything is fine the first time. If I change the position of assemblycomponentoccurences and do the same again it stops at the same position as the previous run.
I suspect that this is due to internal caching of proxies or something.
See attached code and dataset to reproduce.
Please post suggestions and ideas for how to resolve this.
I installed this but to no use. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17804829&linkID=9242019
using System;
using System.Management.Instrumentation;
using System.Runtime.InteropServices;
using Inventor;
using Microsoft.VisualStudio.TestTools.UnitTesting;
namespace SimulationInventorHandlerTest.Utilities.Assembly
[TestClass]
public class DriveConstraintTest
[TestMethod]
public void ProbeTest()
Application inventorAppliaction = GetInventorAppliaction();
AssemblyDocument assemblyDocument = GetActiveAssemblyDocument(inventorAppliaction);
MateConstraint mateConstraintX = GetMateConstraintByName(assemblyDocument, "Axis X");
Inventor.MateConstraint mateConstraintZ = GetMateConstraintByName(assemblyDocument, "Axis Z");
assemblyDocument.ModelingSettings.InteractiveContactAnalysis = Inventor.InteractiveContactAnalysisEnum.kAllComponentsInteractiveContact;
assemblyDocument.ModelingSettings.InteractiveContactSurfaces = Inventor.InteractiveContactSurfacesEnum.kAllSurfacesInteractiveContact;
mateConstraintX.Offset.Expression = "0 mm";
mateConstraintZ.Offset.Expression = "20 mm";
assemblyDocument.Update();
Drive(0, 10, 0.1, mateConstraintX);
double stopPosition = mateConstraintX.Offset.ModelValue;
mateConstraintZ.Offset.Expression = "0 mm";
if(Math.Abs(stopPosition - mateConstraintX.Offset.ModelValue) < 0.0001) throw new Exception("Stopped at same position as first run!");
private void Drive(double startValue, double endValue, double incrementSize, MateConstraint mateConstraint )
mateConstraint.DriveConstraintSettings.CollisionDetection = true;
mateConstraint.DriveConstraintSettings.SetIncrement(Inventor.ConstraintIncrementTypeEnum.kIncrementAsAmountOfValue, incrementSize.ToString());
mateConstraint.DriveConstraintSettings.StartValue = startValue.ToString();
mateConstraint.DriveConstraintSettings.EndValue = endValue.ToString();
mateConstraint.DriveConstraintSettings.GoToStart();
mateConstraint.DriveConstraintSettings.PlayForward();
private static MateConstraint GetMateConstraintByName(AssemblyDocument assemblyDocument, string constraintName)
MateConstraint mateConstraint;
Inventor.AssemblyComponentDefinition assemblyComponentDefinition = assemblyDocument.ComponentDefinition;
if (!(assemblyComponentDefinition.Constraints[constraintName] is Inventor.MateConstraint))
throw new InstanceNotFoundException("Not a MateConstraint");
mateConstraint = assemblyComponentDefinition.Constraints[constraintName] as Inventor.MateConstraint;
if (mateConstraint == null) throw new InstanceNotFoundException("No constraint");
return mateConstraint;
private static AssemblyDocument GetActiveAssemblyDocument(Application inventorAppliaction)
AssemblyDocument assemblyDocument;
if (!(inventorAppliaction.ActiveDocument is Inventor.AssemblyDocument))
throw new InstanceNotFoundException("No active asseblydocument");
assemblyDocument = inventorAppliaction.ActiveDocument as Inventor.AssemblyDocument;
return assemblyDocument;
private static Application GetInventorAppliaction()
Application inventorAppliaction;
inventorAppliaction = Marshal.GetActiveObject("Inventor.Application") as Inventor.Application;
return inventorAppliaction;
