InsertConstraint
InsertConstraint
InsertConstraint
I am trying to create an InsertConstraint between a hole in one component
and another component in an assembly. It always fails. My latest try ended
with an alert box that says "Internal Error: Non Unique instances
Selected.". I am sure that the circular edges are correct for each
component. What could I be doing wrong? The component is already positioned
at the correct point and orientation, I just want them to be constrained.
Randy,
Its difficult to comment without looking at your code and the assembly file.
Here is a sample code that worked fine for me:
Sub test()
Dim aDoc As AssemblyDocument
Dim CO As ComponentOccurrence
Dim ACO As AssemblyComponentDefinition
Dim obj1 As Object
Dim obj2 As Object
Set aDoc = ThisDocument
Set obj1 =
aDoc.ComponentDefinition.Occurrences(1).SurfaceBodies(1).Edges(1)
Set obj2 =
aDoc.ComponentDefinition.Occurrences(2).SurfaceBodies(1).Edges(2)
Set ACO = aDoc.ComponentDefinition
ACO.Constraints.AddInsertConstraint obj1, obj2, True, 0
End Sub
Cheers,
Thilak
"Randy Sanders" wrote in message
news:39352E0E1DC155CE1BE70F7365719BE8@in.WebX.maYIadrTaRb...
positioned
jpisarz
Observer
Observer
I had this Problem with a constraint between a face and a workplane. the solution was to create a proxy from the workplane like this:
Set oOldPart = F_InsertNewDialog.BasePlane
oNewPart.CreateGeometryProxy oNewPart.Definition.WorkPlanes.Item(3), oProxy
oDocument.ComponentDefinition.Constraints.AddFlushConstraint oProxy, oOldPart, 0
maybe it's your way too.
jpisarz
Observer
Observer
oops, I think this looks better:
